88-89 Integra pistons???
Old Sep 1, 2002 | 08:53 AM
sicivic's Avatar
Default 88-89 Integra pistons???
Will 88-89 Integra pistons in D16A6 block work with a Z6 head. Or will there be problems with the valves hitting the pistons? Also, if so, would a cam work or would it cause problems? Hopefully someone knows this.
So, should I up the compression with the 88-89 Int. pistons or should I take out the Z6 head gasket and replace it with a Y8 head gasket. Please let me know what you have found that works together. Thanks
Old Sep 1, 2002 | 08:56 AM
89 CRX SI's Avatar
Default Re: 88-89 Integra pistons??? (sicivic)
donno. but in your mini me swap. did you usde the Z6 timing belt??? and did you use the Z6 timing gear.
Old Sep 1, 2002 | 09:06 AM
sicivic's Avatar
Default Re: 88-89 Integra pistons??? (89 CRX SI)
yea, I used the Z6 timing belt and Z6 cam gear
ERKK
27
Sep 19, 2008 06:20 PM
The Internet Tough Guy
11
May 3, 2006 05:23 PM
civicracer13
10
Feb 12, 2003 04:35 AM
turbohf
Apr 29, 2002 12:28 AM
