timing belt broke help me please
i was going down the road the other day and my fu*king timing belt broke. could it have jumped timing? what about my head? and what to do about help somebody!!!!!!!!!!! asap
um ok well dependsing on lucka dn how fast your going how quick yous topped etc. your head could be ok or your vlaves could be mashed into your pistons.
pull the head ansd see
i had just took off from a light so i was proably doing 50-55. could i just put the belt on and hope like hell it works?
did it snap or falll off. you want to put a new belt back one and see is it works?
I guess if you set the crank to TDC then go the cam gear aligned put the belt on you might be able to give it a try. it either will owrk or not ata ll.
IM me if you need help with the belt...
Damn, that sucks.... Ive had this happen to me before, and it will not be cheap. Be prepared for bent valves. If your motor was running above idle speed at the time, chances are you bent more than a few valves. It would probably be cheaper just to get a new head. If you have access to a machine shop, you can fix your valves; which may not be a good idea depending how many are actually bent. Theres a SLIGHT chance everything is OK and all you need is a timing belt.. but it really depends how you handled the situation. If you shut down the engine quickly you might have a better chances, if you ran the motor.... good luck..
You will more than likely have a couple bent valves. replace the belt, and water pump while your at it, and start her up. Depending on how many valves are bent it should run alright, but TICK like a ****.
slide inside
Oct 22, 2009 09:25 AM
tur3oDC4
Dec 4, 2005 09:12 PM
