car turns over but doesnt start
Old Nov 20, 2009 | 08:05 AM
Dc-2Luke's Avatar
Default car turns over but doesnt start
The problem I have is I replaced my ignitor coil because my car wasn't even turning over before, so now that fixed that problem but now my car turns over but doesn't start, I replaced the spark plugs and that didn't do anything, i swapped the old ones in, and still nothing. Could it be I need a whole new distributer?
Old Nov 20, 2009 | 08:17 AM
na+b18c_hatch's Avatar
Default Re: car turns over but doesnt start
well did you replace the coil or the ignitor? what about the cap and rotor? it also could be a fuel problem instead of a spark problem.
Old Nov 20, 2009 | 09:08 AM
LHC_90_acura's Avatar
i had this same problem with my car and it ended up being a timing problem
Old Nov 20, 2009 | 09:37 AM
mouab18c1's Avatar
did you mark your distributor before you took it off to make sure everything lined up after you put it back on? your ignition timing could be off try moving the distributor around while someone tries to start it.
Old Nov 20, 2009 | 02:30 PM
Dc-2Luke's Avatar
I replaced the ignitor coil it was one piece.
Old Nov 20, 2009 | 02:41 PM
541DB1's Avatar
Main Relay? Sounds like the same problem I had and it ended up being the main relay.
Old Nov 20, 2009 | 02:53 PM
accord99power's Avatar
check for fuel before anything else, easy test. carb or throttle body cleaner past the throttle body shut and try again. If fires for a second you have fuel problem. timing should be fine unless you changed the timing belt recently.
cream1316
May 15, 2011 09:32 AM
SOHC_civic_si
17
Jul 29, 2008 06:17 PM
live_again_integra
Jan 4, 2007 05:42 PM
sikluder
May 4, 2006 04:26 AM
rkkandah
Jan 5, 2006 07:17 PM
