Clutch pedal goes to floor
Old Nov 19, 2009 | 06:46 PM
fcjohnny's Avatar
Default Clutch pedal goes to floor
I was driving to bring my friend home and my Clutch pedal loses a lot of pressure. I have to press the clutch all the way to the floor for I to engage. What the hell cause this? Drive a 94 rs
Old Nov 19, 2009 | 07:00 PM
gabe768's Avatar
Default Re: Clutch pedal goes to floor
check to see if your topped off with brake fluid, that happened to me and that was the problem
Old Nov 19, 2009 | 07:11 PM
seanbev24's Avatar
I'd start by inspecting for leaks and bleeding the system with new fluid since it'll only put you out a few bucks.
If that doesn't work, it could be a bad master cylinder, slave cylinder, maybe pressure plate?
Old Nov 19, 2009 | 07:33 PM
ILS_09's Avatar
Check for any leaks from your slave cylinder and clutch master cylinder. Typically, the clutch/brake fluid for the clutch reservoir wouldn't go down unless there is a leak somewhere. Make sure your clutch reservoir (or whatever it's called) is full.
EddieLe76
Jan 14, 2010 01:50 PM
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
eg6sittingon57cs
Aug 8, 2007 10:44 AM
The Droogan Leader
Oct 6, 2006 12:05 PM
