tire sizes 185/65/14-185/70/14
Old Nov 19, 2009 | 05:34 PM
hesson81's Avatar
Default tire sizes 185/65/14-185/70/14
Hello, I used to have a Honda accord 91. I bought winter tires for it last year, got one season out of them, and bought new tires for it in april. It finally had enough at 250K miles, so I bought a used Civic. it's a 97. The accord, used 185/70/14, the civic uses 185/65/14's... It need tires, i was looking for some, but a friend of mine seems to think that I might be able to use the 185/70's on the civic??
What Do you think? Same width, but I don't know about the Ratio or how that works, I'd like to save some money....
Old Nov 19, 2009 | 06:47 PM
98civdx's Avatar
Master Detailer
Default Re: tire sizes 185/65/14-185/70/14
i would not put that big of tire on a civic ever.
look at 195-55-14.
do you want to keep the same wheel?
Old Nov 19, 2009 | 07:46 PM
90_EX_Civic's Avatar
op, you'll be fine. your speed will be off though.
Old Nov 19, 2009 | 10:04 PM
Del Namco Solo's Avatar
personally never go up on the middle number.
My del sol came with 185-60-14's I upgrade to 195-60-14's. (width, sidewall, rim size)
I'll never go back to 185.... next though is upgrade to a 15 or 16 with 205's and a nice big brake kit....
Old Nov 20, 2009 | 09:26 AM
ChRiS_p123's Avatar
you do realize that your "middle number" did go up right. the middle number is a ratio not a number. it is a percentage of the tire width. so you going with a wider tire with the same middle number makes your sidewall slightly larger.
Old Nov 20, 2009 | 10:10 AM
hesson81's Avatar
look at 195-55-14.
Yea, I wanna keep the same wheel. I guess I shouldn't do it....
Old Nov 20, 2009 | 12:00 PM
98civdx's Avatar
Master Detailer
you could do it, but i wouldnt just my 2 cents.
Old Nov 20, 2009 | 01:32 PM
JDMCIVIC97's Avatar
185/60/14 Thats the size I use for winter on my honda steelies
I believe thats the lowest profile you can do on a 14 for everyday use tires.
sol_cal
Sep 20, 2014 04:37 AM
xPRIMO
Mar 7, 2012 11:05 AM
itsmejto
Jul 13, 2008 08:42 AM
wrx'n you
Sep 22, 2005 04:39 PM
Family Man
Jan 10, 2005 08:52 PM
