Want to Buy Want to Trade/Want to Buy
wtb: b16a rebuild parts
Old Nov 19, 2009 | 01:13 PM
overrev_it's Avatar
Default wtb: b16a rebuild parts
sufficient for a 500 hp rebuild?
Part Description
B16A cylinder head gasket (81.50mm)
B16A timing belt 14400-P2T-004
tensioner bearing 14510-P30-003
tensioner bearing adjuster spring 14516-PR4-A00
cam shaft seal QTY.2 91213-PR3-004
cam cap o-ring 91302-GE0-000
intake valve stem seals QTY.8 12210-PZ1-004
exhaust valve stem seals QTY.8 12211-PZ1-004
IACV gasket 36455-PT3-A01
IACV coolant flange gasket 36455-PV0-000
IAT Sensor o-ring 91303-PD1-910
FPR o-ring 16741-PG7-005
MAP sensor o-ring 16075-P07-000
rocker arms oil rail o-ring (6.8X1.9) 91306-PJ4-000
cam plug 12513-P30-000
valve cover rubber gasket 12341-PR3-000
spark plug o-rings/seals QTY.4 12342-PG6-000
valve cover rubber washers QTY.8 90442-P30-000
intake manifold gasket 17105-P30-004
distributor o-ring 30110-PA1-732
oil pan gasket 11251-P30-004
block oil orifice o-ring 15142-PH3-003
oil pump 15100-P72-A01
oil pump o-ring 91302-PF0-003
oil pickup gasket 15221-PW0-S01
breather chamber o-ring 91324-Pr3-003
oil cooler o-ring 91316-PE7-730
5/8" barbed fittings - 11107-PK2-003
water pipe o-ring QTY.2 91314-PH7-003
thermo switch assembly 37760-P00-004
thermostat assembly 19301-P08-316
Plastigage, Green Kit, 0.001 in.-0.003 in. Clearance Range
ARP Assembly Lubricant
Torco MPZ Engine Assembly Lube - 12oz.
BYE
Old Nov 19, 2009 | 02:51 PM
Sales@Bisimoto.com's Avatar
Default Re: wtb: b16a rebuild parts
Sent you a PM!
Old Nov 22, 2009 | 12:10 AM
overrev_it's Avatar
upppppppppppppppppppppppppppppppppp
Old Dec 10, 2009 | 02:01 AM
Romo Pyro's Avatar
http://www.hondamarketplace.com/show....php?t=2693084
obo 4 u. lmk.
Squigget
Feb 8, 2020 07:12 PM
BertDog
Mar 12, 2012 07:19 AM
raverx3m
Jan 13, 2011 01:30 AM
walrus_07
Mar 7, 2009 01:21 PM
seifer
Feb 22, 2005 06:01 AM
