Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Noise & Black Smoke from under the hood...
Old Nov 19, 2009 | 07:12 AM
chs's Avatar
chs
New User
Default Noise & Black Smoke from under the hood...
Hi,
I've got a 2002 Honda Odyssey EX. Twice in the last 7 days it has exhibited some very odd behavior. The first time it was idling and there was a noise under the hood that sounded almost like popcorn popping (my wife's description) or if you put a pencil in and out of a moving fan (my description). It then started smoking profusely. I immediately turned it off, popped the hood, and inspected. Found nothing visually wrong from what I could see. All fluid levels fine and nothing dripping on the ground. Turned it back on again shortly after and it functioned perfectly for 5 days. Then it happened again. This time my wife was driving and she thinks the cadence of the noise increased with acceleration and noticed a definite heat when she got out and went to the front. She stopped and turned it off. Had it towed to our trusted mechanic and he could find no evidence of any problem ( he didn't start taking stuff apart though). I have since been driving it for 2 days since the last episode and it is running normally.
Does anyone have any idea what it might be?
Thanks in advance.
Old Nov 19, 2009 | 11:01 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Noise & Black Smoke from under the hood...
Black smoke? That would usually be fire of some sort... I don't know of any issues that would cause that. Did you see if any wires are messed up? Maybe hitting a fan or a pully?
Old Nov 19, 2009 | 11:59 AM
chs's Avatar
chs
New User
Well, it stops when we shut the car off. Then start it again minutes later and it runs perfectly. Belts seem okay. Which wires would you check?
Old Nov 20, 2009 | 07:54 PM
www.megameet.org's Avatar
we cant figure it out on here. This needs a set of eyes. You dont have any info for us to give you a correct assumption, or guide to fix.
Old Nov 20, 2009 | 08:00 PM
David12's Avatar
if the mechanic couldn't find the problem you took it to the wrong mechanic.
MonkeyConQueso
Honda Civic (2006 - 2015)
Jan 31, 2007 09:37 AM
asharerin
Aug 25, 2004 12:15 PM
