FOR SALE: EM1 Civic Si Front Swaybar 26mm
This is an EM1 Civic Si 26mm Front Sway Bar
with
Genuine Heim Joint End Links
The following will be include with the sell:
*EM1 Civic Si 26mm Front Sway Bar
*EM1 Civic Si Sway Bar Mounting Bushings
*EM1 Civic Si Sway Bar D- Rings
*All the necessary hardware
* Heim Joint End Links
*New End Link Bushings
**Note**
**WILL WORK WITHOUT SI FRONT CONTROL ARMS**
**Best upgrade for elminating chassis roll**
**The items is meant for specific use with an EK chassis**
Photos of the item for sale can be seen via the link below
http://img14.imageshack.us/img14/8994/swaybar.jpg
http://www.rpmcat.com/images/END-SPF-3.jpg
As a side note i have never had any issues at all with this item I just need some extra money at the moment.
I would like to get $120 OBO
Form of Contact
M
with
**Note**
Form of Contact
M
untrue i have GSR FCA's and it work perfectly fine since i am using a heim joint with a bolt through two bushings threaded to the heim joint to make the connection have been working this way for 2 years
silverb18
19
Apr 23, 2004 12:04 AM
