Brake bleeding question
Old Nov 18, 2009 | 03:55 PM
Elvis1977's Avatar
Default Brake bleeding question
I have a 98 accord with 189k 4-cly.
If I siphen up as much brake fluid in the reservior out, do I HAVE to bleed my brakes after I fill it back up with fresh brake fluid? At no time did I press the brake pedal until the resevior was completely full again.
Old Nov 18, 2009 | 04:24 PM
shahriar35's Avatar
Default Re: Brake bleeding question
Whats the point of that then?
I mean you still have the old fluids in the lines. Why not just flush it completely.
Old Nov 18, 2009 | 04:34 PM
Elvis1977's Avatar
Nobody here to help me bleed my brakes. So, will air get into my system as described?
Old Nov 18, 2009 | 05:22 PM
gianinline's Avatar
If you pumped the brake pedal when the reservoir was low, then the probability that air was sucked into the lines is pretty high, which would mean, continue pumping until any sign of air in the lines is no longer coming up.
Old Nov 19, 2009 | 05:22 PM
fleetw00d's Avatar
Get yourself a vacuum bleeder kit. If you start at left rear, then right front, right rear, left front, you should be OK. Put the vacumm hose on the bleeder screw, loosen the screw, continue pumping the vacuum handle until you get clean fluid at each wheel. Stop occassionally to refill the master cylinder (DON"T let it get empty!).
Old Nov 19, 2009 | 05:34 PM
96CiviCoupe's Avatar
there is also gravity bleeding since you're by yourself
Old Nov 19, 2009 | 06:47 PM
TheMuffinMan's Avatar
He knows where you live!
This seems silly......
Your brake lines are still going to be filled with old fluid, as are your calipers. If you sucked out half the stuff in the reservoir then pumped the brakes while bleeding a specific caliper then capped it off and continued the process like 50 times I'm sure you could change out the fluid.
Or you could just go to a shop and pay them $50 to do it properly.
henni
Aug 15, 2009 03:56 PM
tommyofyork
Apr 8, 2007 05:45 PM
JoSi
10
Nov 4, 2006 08:18 PM
Nessal
Sep 3, 2005 06:24 PM
ITR632
Jan 6, 2002 04:27 PM
