Tranny fluid leak
Old Nov 18, 2009 | 01:33 PM
Inextricabledrvr's Avatar
Default Tranny fluid leak
What is the best solution to correct this problem? I do notice a small leak because I see it on my polk a dot driveway now.
Im assuming I need to redo my seals or gaskets around the tranny, but is there anyway to correct this temporarily or do I just keep toppong off every X,XXX amount of miles?
Old Nov 18, 2009 | 02:04 PM
pentaq's Avatar
Default Re: Tranny fluid leak
Have the same issue. Nothing comes to my head besides of pulling tranny out, crack it open and make a new seal.
Old Nov 26, 2009 | 07:43 AM
Remiss's Avatar
does it leak from the seal?? ... might just be the train bolt
when was the last time you changed the tranny fluid??
Wynn`s tranny stop leaks works pretty good ... but even then it is a temporary solution
Old Nov 26, 2009 | 08:11 AM
Acidcrakker's Avatar
First you have to find out where the leak is coming from. It might not even be a tranny leak.
It could be your axle seals.
I would locate this problem first before you start ripping trannies out
Old Nov 26, 2009 | 11:03 AM
mkazm83's Avatar
Agreed. I had a axle seal leak which would stain the driveway.
95redeg6
Aug 24, 2006 09:55 PM
turbotime
Aug 17, 2004 08:44 AM
AgentJam
Oct 16, 2003 04:03 PM
