tuning question?
Old Nov 18, 2009 | 12:32 PM
meheartmycivic's Avatar
Default tuning question?
I have an 00 si with a modified b16.
type r cams, header, intake manifold, throttle body
intake
port polished head
straight pipe
greddy
stage one racing clutch with an 8lb flywheel
jdm p30
b&M fuel pressure regulater
im going to get an hondata s300j tune. i plan to get more engine parts later. will i have to retune it? thanks
Old Nov 18, 2009 | 01:04 PM
azandford's Avatar
Default Re: tuning question?
depends on what you are going to add later
Old Nov 18, 2009 | 01:43 PM
CivicSpoon's Avatar
Yes, you will need a retune. Adding parts will change the way the engine behaves, it will change how much fuel and ignition timing it will need to run it's best. With some modifications, you can get away without a retune, but it will always run better with a new one.
Old Nov 18, 2009 | 03:36 PM
azandford's Avatar
IF you have a good tuner he can sometimes adjust your tune based off what you have done ( not all the time) and just email it to you with the s300 and upload it yourself. I replaced my cam and had my tuner send me a new tune. Works great!
Old Nov 18, 2009 | 04:35 PM
CivicSpoon's Avatar
It doesn't matter how good a tuner is, if they are sending you a map without retuning your car, then it's just a basemap and nothing more. It's basically just the tuner guessing about what will work (an educated guess but a guess nonetheless). Even if it's a map that was made with someone else car, that had the same exact setup, it's still not going to be nearly as good as a full retune.
Old Nov 18, 2009 | 07:12 PM
itsnotfast's Avatar
100% Correct
Jap_Spec_Imports
14
Jan 10, 2008 09:49 AM
b20civicboi
Jan 28, 2007 06:21 PM
iperez
Jan 10, 2007 07:28 AM
civic_hatchback
May 15, 2004 04:18 PM
