Snap ring - Broken in 3 pieces
Yup. So I heard a metallic clunking noise that started around 2000rpm. It was generally sparatic, and sounded like it was coming from the transmission area. I dropped my trans to check it out and when I took out the large bolt that covers the snap ring area I noticed that my snap ring was in 3 pieces! I split the case and everything looks fine inside the case, no gear/bearing wear...any idea how this could have happened? Or whether this could be causing the noise from the transmission. Obviously I'm going to buy a new snap ring tomorrow from Honda, but should I be replacing anything else in there while it's apart?
Maybe a different issue, but the transmission never liked shifting into first or reverse, maybe because of play in the countershaft when the snap ring began to fail?
eh2_Trav
Transmission & Drivetrain
Oct 28, 2018 07:35 AM
portenio78
Feb 26, 2012 12:25 PM
