ZC Piston Replacement?? Help
Besides the 89 Integra... Does any other Piston fit the ZC? Im looking for some good performance pistons. I need a similar car to get info to match the ZC Pistons. What about the D16A's or D16Z's I know there rods fit the ZC. Comments and Tips are welcome... Thanx.
I have a clean set of stock zc pistons sitting around if you need them. I can sell for cheap. Otherwise, I had a set of JE pistons (for the CRX Si motor) fit into the ZC w/ my turbo setup.
ZC Motor guys... Where did you guys buy your Rods, Bearings and Pistons I think I can pull off some CRX Si/ Civic Si Pistons and D16 Eagle Rods? What about Rod Bearings? Just get the matching ACL rod bearings to fit a CRX Si/Civic Si Crankshaft? Comments are welcome.. I have tog o shopping this week. ITs getting cold here.. need this swap done ASAP and broken in so I can Boost before Halloween
Ive been looking at some parts catalogs and I do believe the bottom end parts (main bearings, rod bearings, rods) for a ZC can be swapped from a 88-91 Civic Si or CRX Si. IF this is true according to many parts lists, This would greatly ease the search for ZC parts
The Brown Kid
Aug 5, 2002 10:01 AM
