94-01 GS-R COMPLETE head p72 usdm 575$ shipped FIRM
Looking to just get rid of this head, sitting around for nothing, people are telling me by the stamp is a 1997? I have the title from the car it came out of it, I will send the title with the head. Unless someone changed the head before I bought the car then its a 94.
Kyle Murphy
112 Birch Point Lane
Milo, ME 04463
AIM: smoothmurph102
207-279-0294
575 shipped!
complete head out of a 1994 Acura Integra B18 GSR P72 USDM head. Comes with: Head, valves, cams, valve cover, DISTRIBUTOR new last year, vtec selenoid, intake and throttle body along with fuel rail, cam gears, plastic covers, exhaust studs and most nuts, all vaccum lines, and whatever else you might need. Does need 2 studs from ARP that hold on the center plastic wire cover. Also comes with carquest plug wires on the dizzy. will send the plugs but they need to be changed. ALL MOTOR WORK DONE BY ARP, over sized 1mm valves, newer JDM cams with 40k on them, head is decked for 91+ octane running 10:5 compression, valve cover is sprayed black with yellow powdercoat under it paint can most likely be taken off so its yellow and clean again, comes with a good valve cover gasket, good injectors, everything worked it came off a running car, dizzy came from napa paid somewhere around 300 for it. will send a exhaust gasket thats used, shouldnt leak, and a head gasket OEM i bought and ran for 1500 miles don't know if its reusable. DIZZY IS NOT IN THE PICTURES! IT IS LIKE BRAND NEW. WILL THROW IN ANYTHING ELSE YOU NEED IF I STILL HAVE IT.
dizzy:
http://cgi.ebay.com/ebaymotors/ws/eB...g#ht_716wt_681
Kyle Murphy
Milo, ME 04463
AIM: smoothmurph102
207-279-0294
575 shipped!
dizzy:
highbrid
May 8, 2003 10:38 AM
