Transmission & Drivetrain Gearboxes, Differentials, Clutches
Input shaft bearing or throwout bearing
Old Nov 17, 2009 | 11:35 AM
theappe's Avatar
Default Input shaft bearing or throwout bearing
Ive asked this question in other forums and I get mixed answers... maybe i will get a better one here.
When im in gear the tranny whirrs
When I step on the clutch the noise goes away
When im in neutral there is no noise with the clutch pressed
Would this be the input shaft bearing or the throwout (clutch) bearing.
**UPDATED** read below.
Old Nov 17, 2009 | 10:32 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Input shaft bearing or throwout bearing
ISB
Old Nov 18, 2009 | 04:20 AM
theappe's Avatar
Could it be the ISB and the Throwout?
Old Nov 18, 2009 | 09:56 AM
Mista Bone's Avatar
D Tranny Guru
TOB if bad will make noise with clutch disengaged, yours is making noise with clutch engaged.
ISB
Old Dec 3, 2009 | 09:46 AM
theappe's Avatar
Update:
I dropped the tranny and changed the ISB. I put everything back together and now my gears are really hard and I cant get into reverse. It doesnt even grind reverse.
I made sure that the gear selector was put in neutral along with the forks.
Got any suggestions?
Old Dec 3, 2009 | 09:51 AM
theappe's Avatar
another question...
is it possible to over tighten the detent ***** and that causes my gear to be really hard?
Old Dec 3, 2009 | 10:05 AM
FerreiraCompetitions's Avatar
Originally Posted by theappe
another question...
No because they are spring loaded.
Now the problem with the gears being hard has to do with the way you put the tranny back together.
As for the previous problem, was that fixed?
Old Dec 3, 2009 | 10:31 AM
theappe's Avatar
You mean the bearing? If that was your question than yeah I changed the bearing without a problem.
My guess is that there is something wrong with the way im putting something back together.
Gear selector and forks? I mean this isnt that difficult, but I dont know what to look for as far as something wrong.
Old Dec 7, 2009 | 06:56 AM
theappe's Avatar
bump
help?
Old Dec 8, 2009 | 07:35 AM
theappe's Avatar
bone/aqua?
Old Dec 8, 2009 | 08:40 AM
Aquafina's Avatar
Incorrect.
B or D series?
Old Dec 8, 2009 | 09:57 AM
theappe's Avatar
D series
Old Dec 8, 2009 | 10:39 AM
Evs-One's Avatar
Solbros Owns Me
i've seen many people either not replace the detent bolt crush washer, or lose it, and cause all sorts of shifting issues.
Buy a book and start over
Old Dec 8, 2009 | 11:12 AM
theappe's Avatar
All the washers on the detent bolt are accounted for So I dont really see where I could have messed up...
Its not rocket science, but I cant seem to get it right. I'll try messing with it some more lol.
Old Dec 8, 2009 | 11:13 AM
theappe's Avatar
Oh btw you mean a helms manual?
Old Dec 8, 2009 | 12:20 PM
Aquafina's Avatar
Yes.
Old Dec 8, 2009 | 03:20 PM
Evs-One's Avatar
Solbros Owns Me
Originally Posted by Aquafina
Yes.
Old Jan 13, 2010 | 06:09 PM
99kleansi's Avatar
I am having the same issues trying to fix this noise that goes away with the clutch pressed in.
I believe you can over tighten these spring loaded bolts especially if the washer is missing or too thin. I did it on my first rebuild and could not shift. Upon tear down the ball had pushed itself into the bolt.
CalhounBoi
13
Feb 28, 2007 06:23 PM
mr_nemesis2003
Nov 14, 2006 01:04 PM
uNF$@#!
May 13, 2005 07:59 AM
Ditdogs
Apr 17, 2004 10:57 PM
Takeoff
Dec 11, 2003 06:45 PM
