10K Honda Inventory, Anyone Interested?
Old Nov 17, 2009 | 09:47 AM
juevi's Avatar
Foreign Symbols
Default 10K Honda Inventory, Anyone Interested?
Anyone interested in a bundle? Let me know what you'd pay total and I'll consider. Thanks
A B C J
1 INVNUM INVSTK INVDES current value
2 00295-00103 3.00 SILICONE, OIL PAN FPIG $30.66
3 04152-YZZA1 7.00 FILTER KIT, ENGINE OIL(31090) $22.75
4 04164-SE0-030 1.00 BRAKE HOSES, FRONT $0.00
5 04165-SE0-030 1.00 BRAKE HOSES, FRONT $0.00
6 04174-PC6-660 8.00 TUBE 8X40 ( SET ) $68.48
7 056700-3510 1.00 RELAY $0.00
8 06045-634-670 4.00 PAD SET $60.60
9 06154-PH7-000 4.00 OIL FILTER KIT(n15430-PH7-000) $22.80
10 06164-PG7-A10 4.00 INJECTOR UNIT, FUEL $145.20
11 06452-SE0-A01 2.00 CALIPER SET $31.62
12 065A3-SA5-415 2.00 RACK SEAL KIT (065A1-SA5-000HB $45.78
13 065A3-SD2-415 1.00 SEAL KIT, POWER STEERING B $13.65
14 065A3-SE0-415 2.00 SEAL KIT, P/S (065A3-SE0-405) $45.78
15 065A3-SF1-415 4.00 POWER STEERING SEAL KIT $51.76
16 065A3-SM4-425 2.00 SEAL KIT, P/S $56.52
17 065B3-SA5-405 1.00 RACK SEAL KIT (065B1-SA5-000HB $7.05
18 065B3-SD2-405 3.00 SEAL KIT, STEERING $12.42
19 065B3-SE0-405 3.00 POWER STEERING SEAL KIT K $21.15
20 065B3-SF1-405 2.00 SEAL KIT $8.34
21 065B3-SM4-405 2.00 SEAL KIT, P/S $14.94
22 06764-SA5-003 2.00 BRACKET, MIRROR REPAIR (HATCH) $11.44
23 06764-SG0-000 2.00 BRACKET, MIRROR REPAIR ( 4DR ) $11.86
24 06923-P0A-306 1.00 RETAINER, BAL SHAFT SEAL $1.97
25 08922-02011 2.00 FILTER,OIL (w02004n9091503002) $4.78
26 08F02-SK8-AM001 1.00 RELAY $13.46
27 10 MM NUT 14.00 $0.00
28 10W/30PLM-A01 3.00 FILTER, ENGINE OIL $7.50
29 11105-657-300 2.00 FREEZE PLUG ( 30MM ) $0.00
30 11105-689-300 1.00 FREEZE PLUG ( 35MM ) $1.67
31 11105-PH3-000 4.00 CAP, SEALING $21.88
32 11106-PR4-305 3.00 BOLT, GALLEY PLUG $10.86
33 11251-P01-004 4.00 OIL PAN GASKET (11251-PE2-004) $28.24
34 11251-P0A-000 4.00 GASKET,OIL PAN(w11251-PT0-000) $49.52
35 11251-P2F-A01 2.00 GASKET, ENGINE OIL PAN $16.38
36 11251-PC0-014 1.00 OIL PAN GASKET $9.00
37 11251-PC6-010 1.00 GASKET, OIL PAN $6.83
38 11251-PH7-000 1.00 OIL PAN GASKET $7.44
39 11251-PK 1-000 3.00 GASKET, OIL PAN $24.42
40 1156 14.00 MINI LAMP $11.20
41 1157 4.00 BULB $1.60
42 1157A 7.00 BULB $11.90
43 11854-PH3-000 1.00 JOINT, BR. $2.70
44 11855-PH3-000 1.00 TUBE A, PCV $12.45
45 11855-PH3-J01 1.00 TUBE A, PCV $12.20
46 11855-PR3-000 1.00 TUBE $8.11
47 12030-P01-020 1.00 VALVE COVER GASKET SET $19.76
48 12030-PY3-000 2.00 Gasket, valve cover $35.58
49 12209-657-000 12.00 SEAL VALVE STEM $31.56
50 12209-PA5-004 4.00 SEAL VALVE STEM (PA6-003) $10.52
51 12209-PA6-003 4.00 SEAL VALVE STEM $3.20
52 12209-PD2-003 12.00 VALVE STEM SEALS $20.76
53 12211-PE0-004 4.00 VALVE STEM SEAL $8.80
54 12332-PH7-003 3.00 SEAL, VALVE INSP COVER $11.82
55 12341-P0A-000 2.00 VALVE COVER SEAL $12.28
56 12341-P8A-A00 2.00 CAM COVER SEAL $8.84
57 12341-PA6-000 1.00 CAM COVER SEAL $6.44
58 12341-PC6-000 1.00 CAM COVER SEAL (12341-PH4-000) $4.61
59 12341-PE0-000 1.00 CAM COVER SEAL $3.97
60 12341-PE0-661 9.00 SEAL, CAM COVER $46.35
61 12341-PE2-003 3.00 COVER SEAL $16.92
62 12341-PH7-000 1.00 CAM COVER SEAL (nP0G-A00) $6.00
63 12341-PK2-010 1.00 VALVE COVER SEAL $6.11
64 12341-PM7-000 1.00 SEAL, V/C $6.33
65 12341-PR3-000 6.00 GASKET, CYL HEAD COVER VTEC $40.50
66 12341-PT2-000 3.00 GASKET, HEAD COVER $27.24
67 12342-P8A-A01 3.00 SPARK PLUG SEAL $3.18
68 12342-PT0-000 4.00 GASKET, spark plug $4.84
69 12342-PT2-000 11.00 SEAL, SPARK PLUG $7.70
70 12345349 5.00 GEAR OIL $52.90
71 12415-PH7-003 2.00 PCV COVER GASKET $4.64
72 1273 12.00 Spark plug, NGK $17.16
73 13404-PT0-004 1.00 TENSIONER, BALANCE BELT $17.50
74 13758 1.00 THERMOSTAT $0.00
75 14056-77A01 1.00 HOSE, BYPASS $9.77
76 14400-PK1-004 2.00 TIMING BELT $57.28
77 14400-PR3-004 2.00 TIMING BELT $86.26
78 14510-PT0-004 1.00 TENSIONER, TIMING BELT $13.67
79 14777-657-000 8.00 HOLDER GASKET $13.92
80 14777-689-000 18.00 HOLDER GASKET $32.76
81 14777-PC6-000 27.00 GASKET, AUXILLARY VALVE HOLDER $36.45
82 14777-PE0-000 19.00 GASKET, AUXILLARY VALVE HOLDER $20.52
83 15103-PC6-003 2.00 GASKET $3.06
84 15113-PT0-003 11.00 SEAL, OIL PUMP $28.60
85 15114-PT0-003 3.00 GASKET, OIL PUMP $6.06
86 15115-P8A-A01 1.00 OIL PUMP GASKET $1.52
87 15142-PE0-000 14.00 O-RING $6.30
88 15165-70010 1.00 SEAL, OIL PUMP SHAFT $5.11
89 15205-PC6-014 16.00 GASKET, OIL PUMP $42.72
90 15610-611-000 2.00 OIL FILLER CAP $13.24
91 15610-PC6-000 2.00 CAP, OIL FILLER $10.92
92 15705-PH7-000 1.00 PCV TUBE $6.07
93 1578535010 3.00 GASKET $0.00
94 16010-S84-A01 1.00 FILTER, IN-TANK FUEL $12.44
95 16010-SE0-G31 1.00 FUEL FILTER ( n16010-SE0-G32 ) $8.95
96 16010-SF0-671 3.00 FUEL FILTER ( 16900-SF0-670 ) $40.98
97 16010-SF1-A31 1.00 FUEL FILTER ( 16010-SF1-A32 ) $16.78
98 16010-SK7-A30 1.00 FILTER, FUEL INJ (nA62,SS1-930 $16.00
99 16010-SM4-931 1.00 FUEL FILTER (n932 ) $13.25
100 16010-SM4-K50 1.00 FUEL FILTER $12.88
101 16016-PM6-005 1.00 SCREW, IDLE AIR BLEED $3.56
102 16021-PE0-702 1.00 DIAPHRAGM, ACEL PUMP $24.32
103 16024-PC7-662 1.00 SOLENOID, FUEL $0.00
104 16026-PC7-661 1.00 FUEL JOINT SET $6.17
105 16077-PR3-005 4.00 O-RING $6.68
106 16105-657-000 14.00 SEAL A $30.80
107 16105-PG6-000 3.00 ORING, CARBURETOR $15.90
108 16105-PM5-A00 2.00 SEAL, THROTTLE BODY $3.10
109 16176-P0A-004 2.00 GASKET, EACV $6.70
110 16210-PD2-316 1.00 INSULATOR, CARBURETOR BASE $33.84
111 16215-657-S00 17.00 GASKET. LWR INS(16215-657-000) $50.15
112 16215-689-000 4.00 GASKET, I ( 16215-689-010 ) $5.84
113 16215-PH1-S00 2.00 GASKET $8.14
114 16235-PA6-003 1.00 FUEL FILTER $4.77
115 16258-15011 1.00 $0.67
116 16283-50010 1.00 HOSE, WATER $9.09
117 16325-62010 2.00 THERMOSTAT GASKET $3.08
118 16325-63011 2.00 THERMOSTAT GASKET $1.48
119 16472-P0H-A01 6.00 SEAL, FUEL INJECTOR (nP10-A01) $0.00
120 16472-P10-A01 18.00 SEAL RING, INJECTOR (wPD6000) $94.50
121 16473-PD6-000 8.00 INJEC. CUSHION RING $20.40
122 16474-PH7-000 6.00 INSULATOR, INJECTOR $12.30
123 16474-PT2-000 4.00 INSULATOR $9.08
124 168 4.00 LIGHT BULB, PARKING $2.44
125 16900-SB2-681 1.00 FUEL FILTER (n16010sb2) $9.58
126 16900-SD7-670 1.00 FILTER, FUEL INJECTION $9.95
127 16900-SF0-671 3.00 STRAINER COMP(w670,n16010SF0) $34.08
128 16900-SF1-A33 2.00 FUEL FILTER (16010-SF1-A32) $19.00
129 16900-SM4-A32 1.00 FUEL FILTER (n16010-SM4-A30 ) $10.23
130 17105-P8A-A01 1.00 GASKET, IN MAN PLENUM 3.2L $10.33
131 17105-PG6-S00 1.00 GASKET, INTAKE MANIFOLD $5.56
132 17105-PT2-003 1.00 GASKET, IN MANIFOLD $5.15
133 17121-PV0-003 1.00 INTAKE PLENUM GASKET $5.92
134 17130-PC6-003 1.00 VALVE, PCV (wPEO003) $3.80
135 17130-PE0-003 1.00 VALVE, PCV (nPC6-003) $8.75
136 17130-PK1-003 1.00 VALVE ASSY, PCV $4.23
137 17139-PK1-000 1.00 GROMMET $1.71
138 17176-62030 1.00 GASKET, INTAKE PLENUM $7.83
139 17199-PT3-AHM 4.00 PLUG, EGR PORT $0.96
140 17321-PE0-010 1.00 JOINT NIN $9.41
141 17323-657-670 1.00 JOINT 4-WAY $4.12
142 17328-PH4-660 1.00 HOSE, VACUUM $7.07
143 17330-671-671 1.00 JOINT 4-WAY $2.78
144 17342-76010 1.00 HOSE, AIR NO.2 $9.96
145 17343-76010 1.00 HOSE, AIR NO.3 $13.46
146 17360-PD2-662 1.00 THERMOVALVE $15.17
147 17670-634-013P 1.00 FUEL CAP $4.42
148 17670-SM1-A03 1.00 CAP, FUEL FILLER $4.15
149 17670-SV1-A01 1.00 GAS CAP $3.88
150 17801-03010 3.00 FILTER, AIR INTAKE $27.24
151 17801-0D020 1.00 AIR FILTER $6.84
152 17801-0H010 2.00 AIR FILTER $18.70
153 17801-21040 2.00 AIR FILTER $23.80
154 18010-657-921 2.00 RING SEAL $13.64
155 18015-657-000 6.00 PORT LINER $20.70
156 18115-P2A-003 1.00 GASKET, EX MAN $6.90
157 18116-PC6-010 2.00 GASKET, INT. MANIFOLD $3.20
158 18116-PD2-000 1.00 GASKET, MANIFOLD $1.49
159 18212-671-003 9.00 GASKET, EXH $0.00
160 18212-SB2-961 8.00 GASKET, EXHAUST FLANGE $18.24
161 18215-SA5-900 1.00 RUBBER $0.00
162 18215-SV4-A81 1.00 HANGER, EX PIPE $5.00
163 18229-SH3-X30 1.00 GASKET, EX PIPE $12.00
164 18303-SM4-020 3.00 Gasket, exhaust $8.76
165 18393-SH3-S00 4.00 GASKET, PIPE $20.68
166 18393-SS0-J30 1.00 GASKET, PR $3.07
167 18768-PY3-004 1.00 GASKET $0.00
168 19011-636-013 7.00 RADIATOR PLUG $20.44
169 19011-671-000 3.00 RADIATOR PLUG $2.37
170 19011-PA0-003 4.00 DRAIN ****, RADIATOR $7.00
171 19011-PH1-621 2.00 DRAIN PLUG, RADIATOR $6.64
172 19011-PH2-004 6.00 PLUG, RADIATOR DRAIN $11.34
173 19012-PA0-004 3.00 SEAL, PLUG (w 003) $1.80
174 19045-692-003 2.00 RADIATOR CAP (19045-634-003) $13.38
175 19045-P08-013 3.00 RADIATOR CAP $19.50
176 19045-PM3-003 3.00 RADIATOR CAP $19.65
177 19045-PT0-003 3.00 CAP, COMP. RADIATOR $19.65
178 19101-75010 1.00 CAP, DISTRIBUTOR $12.29
179 19200-PA5-010 1.00 WATER PUMP (19200-PE8-600) $19.58
180 19222-P08-004 2.00 WATER PUMP GASKET $3.84
181 19222-P0G-A01 1.00 WATER PUMP GASKET $2.75
182 19222-P8A-A01 1.00 WATER PUMP GASKET $1.75
183 19222-PC6-000 6.00 SEAL, WATER PUMP $7.08
184 19222-PE0-000 8.00 WATER PUMP SEAL $8.56
185 19222-PH3-003 1.00 GASKET, WATER PUMP $0.00
186 19222-PH7-003 1.00 O-RING, W $2.19
187 19222-PT0-300 4.00 SEAL, WATER PUMP $7.32
188 19300-P08-003 1.00 THERMOSTAT(n19301P08315 $8.50
189 19300-PE0-024 1.00 THERMOSTAT $10.31
190 19300-PH7-024 1.00 THERMOSTAT $7.65
191 19301-P08-316 1.00 THERMOSTAT (w315,305 $10.54
192 19305-689-010 6.00 MOUNT $8.58
193 19305-PC6-000 1.00 RUBBER MOUNT $1.74
194 19305-PJ7-000 2.00 RUBBER MOUNT, THERMOSTAT $1.76
195 19305-PR7-A00 2.00 MOUNT, THERMOSTAT $3.56
196 19305-PT0-000 2.00 MOUNT, THERMOSTAT (wPR3-000) $2.34
197 19311-PC6-000 6.00 COVER, TSTAT $57.36
198 19315-PM3-000 1.00 HOUSING, WATER $5.63
199 194 6.00 BULB $2.40
200 19422-PH7-010 1.00 HOSE, IN $4.19
201 19424-PL2-000 1.00 HOSE, OI $9.67
202 19501-692-000 1.00 HOSE WATER UPPER $13.20
203 19501-PJ6-660 1.00 HOSE, WA $16.70
204 19501-PY3-000 1.00 HOSE, UPPER RADIATOR $9.80
205 19502-PA0-900 1.00 HOSE, RADIATOR LOWER $10.88
206 19502-PJ5-010 2.00 HOSE,WA $33.40
207 19502-PK1-010 1.00 HOSE $17.48
208 19504-657-000 4.00 BYPASS HOSE $70.00
209 19504-PB2-660 1.00 BYPASS HOSE $5.67
210 19504-PC6-010 1.00 HOSE, BYPASS INLET $8.41
211 19504-PE0-010 2.00 HOSE, COOLANT BYPASS $8.96
212 19504-PH7-000 1.00 HOSE, BYPASS $5.92
213 19504-PK1-010 1.00 HOSE BYPASS, IN $4.68
214 19507-PK1-000 1.00 HOSE, WATER CARB. $4.20
215 19507-PT2-000 1.00 HOSE A, (SE) (orPT6) $5.51
216 19508-PD2-000 1.00 HOSE BYPASS $4.14
217 19508-PK1-000 2.00 HOSE A, BYPASS O $7.96
218 19508-PT2-000 1.00 HOSE, BY PASS OUTLET $3.45
219 19509-PK1-000 1.00 HOSE, WATER BYPASS $9.30
220 19510-PT2-000 1.00 HOSE, THROTLE BODY $5.09
221 19511-PH3-000 2.00 HOSE, PC $7.10
222 19511-PH3-J00 3.00 HOSE, PCV $10.47
223 19515-PJ0-661 1.00 HOSE B, BREATHER $5.59
224 19515-PT2-000 3.00 HOSE B $7.89
225 19515-PT2-010 2.00 HOSE B $3.34
226 19521-PT2-000 3.00 HOSE A, OIL COOLER $13.47
227 19525-PG7-660 1.00 HOSE,WTR OUTL (w19524-PE2-000) $5.75
228 22222-0A110 1.00 GASKET, I.A.C. $7.24
229 22271-03030 1.00 Gasket, throttle body $3.52
230 22300-PA6-000 1.00 CLUTCH, PRESSURE PLATE ASSY $40.00
231 22300-PE1-040 2.00 CLUTCH,PRES.PLATE ASSY (PE7030 $144.44
232 22910-SA0-674 1.00 CLUTCH CABLE $16.94
233 22910-SH3-A05 1.00 CABLE, CLUTCH $35.59
234 23291-41010 4.00 INSULATOR $1.32
235 23561 2.00 GASKET $9.72
236 242-1394 10.00 Schrader Valve $15.10
237 242-1403 10.00 HI-SIDE CAP $7.00
238 256-036 1.00 GASKET, EX MUFFLER $1.56
239 256-293 1.00 Exhaust Seal Ring $3.86
240 27-012 1.00 WIPER BLADE ASSY $5.03
241 27-014 1.00 WIPER BLADE $5.27
242 27-024 1.00 WIPER BLADE ASSY $12.89
243 30100-SEAL (BH3888-) 5.00 $0.00
244 30100-SEAL-1 13.00 SEAL, DISTR SHAFT $39.00
245 30102-P0A-A02 2.00 CAP ASSY, DIST nP2M-A01 $18.90
246 30102-P2M-A01 2.00 CAP ASSY (w P0A-A02) $30.96
247 30102-PA1-732 1.00 CAP ASSY, DISTRIBUTOR $3.37
248 30102-PAA-A01 1.00 CAP, IGNITION DIS $10.35
249 30102-PC1-004 1.00 CAP 30102-PA1-732 $2.75
250 30102-PC2-661 1.00 DISTRIBUTOR CAP $6.54
251 30102-PK1-006 1.00 DISTRIBUTOR CAP $16.25
252 30102-PL2-016 4.00 DISTRIBUTOR CAP $27.00
253 30102-PM5-305 1.00 CAP/ROTOR ASSY (A03,A04,A05 ) $14.48
254 30102-PM7-305 1.00 CAP ASSY KIT (W PM5-036) $13.28
255 30102-PT3-A12 3.00 DISTRIBUTOR CAP (wP12-A01) $25.23
256 30103-P08-003 2.00 DISTRIBUTOR ROTOR $17.34
257 30103-P0G-A02 1.00 ROTOR, DISTRIBUTOR $12.38
258 30103-PAA-A01 1.00 ROTOR, DISTRIBUTOR(wP0A-A01 $5.91
259 30103-PM5-A05 2.00 DIST ROTOR ( 30103-PM5-A04 ) $8.26
260 30103-PT2-016 1.00 ROTOR, DIST(n06304pt2j00) $5.26
261 30103-PW0-G03 1.00 DISTRIBUTOR ROTOR $0.00
262 30105-679-015 2.00 CONTACT SET $6.00
263 30108-657-005 17.00 CAPACITOR $23.12
264 30108-PA1-005 2.00 CAPACITOR $2.12
265 30110-PA1-732 5.00 O-RING 26.4X3.1 (or 634,PC6) $5.20
266 30110-PE1-006 5.00 SEAL, DISTRIBUTOR HSNG $6.10
267 30110-PH7-006 1.00 O-RING, DISTRIBUTOR 24.4X3mm $1.22
268 30121-689-005 3.00 STATOR $32.94
269 30135-P08-006 10.00 SCREW, ROTOR $0.80
270 30500-PM5-A03 1.00 COIL ASSY $55.06
271 30500-PR4-A02 1.00 IGNITION COIL $56.01
272 3057 7.00 Bulb $7.84
273 31010-PC2-661 1.00 CONTACT SET, STR SOLENOID $5.92
274 31105-611-024 2.00 BRUSH ASSY $23.06
275 31105-PZ1-003 3.00 BRUSH HOLDER ASSY $43.26
276 31110-P0B-A12 1.00 BELT, ALT DRIVE 6PK-0940 $8.53
277 31110-P1R-004 1.00 BELT, 5PK-0825 $0.00
278 31110-PH7-003 1.00 BELT, ALT 3PK1080 $8.18
279 31110-PH7-013 3.00 BELT, ALT 3PK1077 $29.76
280 31110-PJ7-033 3.00 BELT, ALT (wPG7-661)3PK715 $13.50
281 31110-PK1-003 1.00 BELT, ALT 5PK870 $8.57
282 31110-PK2-004 3.00 BELT, ALT 5PK875 $0.00
283 31110-PL2-A11 1.00 BELT, ALTERNATOR $7.82
284 31110-PR3-003 1.00 BELT, ALT 4PK770 $4.43
285 31110-PT0-004 10.00 BELT, ALT 5PK956 $80.30
286 31114-PL2-000 1.00 BOLT, TEN $5.06
287 31512-SA5-672 2.00 BRACKET, BATTERY HOLD DWN $12.24
288 31513-SA0-670 1.00 BATTERY BOLT $2.16
289 31513-SB2-000 1.00 BATTERY BOLT $2.31
290 3157 7.00 Bulb, wedgebase 27watt $8.12
291 32106-SA5-020 1.00 WIRE HARNESS W/PLUGS $0.00
292 32110-SA5-674 6.00 SUB CORD $168.18
293 32410-SC5-672 2.00 CABLE, STA $34.18
294 32722-PE1-V11 1.00 IGNITION WIRE SET $25.29
295 32723-689-660 1.00 IGNITION COIL WIRE $12.31
296 33143-SA5-671 3.00 SCREW, ADJUST $6.36
297 33503-SM4-003 1.00 GASKET, TAILLIGHT HOUSING $2.79
298 33509-692-003ZD 1.00 NUT, SP $2.10
299 33552-SE3-A01 1.00 HARNESS $21.63
300 33902-SN9-J01 1.00 BULB, FOG LAMP $8.20
301 34253-671-003 5.00 BULB 8W $11.50
302 34901-SB3-671 2.00 BULB, AUX. BRK LMP $2.06
303 34903-SF1-A01 4.00 BULB,12V 115, (W34903-SH3-A01) $7.16
304 34906-MG9-771 5.00 BULB, TAILLIGHT $2.90
305 34906-ST5-003 1.00 BULB, BRAKE (7443) $2.11
306 35130-SM5-305 1.00 SWITCH, IGN SW BACK (or SM4) $37.28
307 35168-21011 1.00 Gasket, transmission pan $6.72
308 35350-SE0-013 1.00 SWITCH, BRK LIGHT $0.00
309 35400-SG0-023 2.00 SWITCH, DOOR INTERIOR $16.36
310 35505-S84-A01 4.00 BULB ASSY $5.44
311 35505-S84-B02 2.00 BULB, NEON (clock) $2.90
312 35506-SA5-003 2.00 BULB 14V $0.00
313 36172-P0A-005 3.00 GASKET, VTEC CTRL SOL $3.93
314 36183-PD2-662 1.00 SWITCH VACUUM, B-40 $35.89
315 36450-PP4-E01 1.00 VALVE ASSY, EACV $106.00
316 36454-PS4-003 1.00 FILTER, EACV VALVE $0.00
317 36455-PT3-A01 2.00 GASKET $3.50
318 37554-SF0-004 7.00 BULB $15.54
319 38442-SA5-003 1.00 WIPER INSERTS $2.15
320 38472-SB2-305 1.00 WIPER INSERT (w003) 450mm $3.14
321 38472-SB3-305 7.00 WIPER INSERT (w003) 475mm $21.98
322 38646-SA5-003 4.00 O'RING $4.52
323 38920-P0G-A01 1.00 BELT, A/C COMP 5PK-0965 $6.00
324 38920-PC1-952 1.00 BELT, COMPRESSOR $6.95
325 38920-PC3-661 5.00 BELT, AC COMP $39.10
326 38920-PC6-003 1.00 BELT, COMPRESSOR $6.32
327 38920-PC7-671 1.00 BELT, COMP $6.62
328 38920-PD2-701 2.00 BELT, COMPRESSOR $9.56
329 38920-PE1-701 4.00 BELT, COMPRESSOR $28.68
330 38920-PH4-662 1.00 BELT,COMP (nPH4-669)4PK905 $4.49
331 38920-PJ6-662 2.00 BELT, COMPRESSOR $14.46
332 38920-PK1-A01 2.00 BELT, COMP 5PK1005 $12.00
333 38920-PM3-014 1.00 BELT $6.50
334 38920-PM5-A21 2.00 BELT, COMP (nA04) 4PK790 $9.00
335 38920-PY3-A01 1.00 BELT, COMPRESSOR 5PK-0965 $7.82
336 38944-PE0-000 2.00 COLLAR ID $5.86
337 39152-SM4-A03 1.00 ANTENNA MAST $38.45
338 39152-SP0-305 1.00 ANTENNA MAST, LGND $49.48
339 39270-SA5-305 1.00 VALVE, HTR CONT $24.57
340 39271-SA0-023 1.00 VALVE, HEATER CONTROL $25.00
341 39311-692-010 2.00 HOSE WATER INLET $28.30
342 39311-SD9-000 1.00 HOSE A, WATER INLET $23.98
343 39311-SF0-000 1.00 HOSE, WA $20.28
344 39400-657-673 2.00 FAN RELAY ASSY $44.24
345 39610-SB8-305 1.00 **** COMP $5.51
346 39795-SB2-003 1.00 RELAY, A/C POWER $25.33
347 42325-671-000 2.00 HOLDER, COTTER PIN $0.00
348 42510-SD4-000 2.00 BRAKE ROTOR $108.76
349 42610-634-010 1.00 DRUM $36.17
350 42610-663-000 2.00 BRAKE ROTOR $0.00
351 43053-671-307 1.00 BRAKE SHOE SET $10.01
352 43240-SA5-951 4.00 BOLT FL, CALIPER $5.36
353 43352-692-003 1.00 BLEEDER VALVE, BRKS $2.17
354 43367-671-631 10.00 SPRING G $0.00
355 43375-SA0-003 8.00 U-CLIP $9.44
356 44017-SR3-000 3.00 BELLOWS KIT (w44315SF4J22) $22.53
357 44018-S84-C00 1.00 CV JOINT KIT $0.00
358 44200-SM4-018 1.00 BEARING, FRONT WHEEL $57.52
359 44300-SB2-004 1.00 WHEEL BEARING, FRT $24.95
360 44300-SE0-018 1.00 BEARING, FRONT AXLE (w008) $38.89
361 44315-SB2-003 2.00 BELLOWS KIT, INNER C.V. JOINT $24.84
362 44315-SM4-003 1.00 BOOT,INNER (nSM1A01) $5.42
363 44318-634-300 11.00 BAND BELL ( FBB-1 ) $12.76
364 44319-SA2-000 2.00 SET, RING 26X1.8 $3.00
365 44319-SR1-003 2.00 CLIP, AXLE SET RING $0.00
366 44327-30030 2.00 GASKET, PS OUTPUT $7.04
367 44333-SA7-013 2.00 C.V. BELLOWS $12.30
368 44333-SB2-761 3.00 BOOT A $23.73
369 44333-SB2-962 4.00 BELLOWS, C.V. JOINT OUTER(961) $28.48
370 44333-SF1-013 1.00 BELLOWS, CV JOINT OUTER $7.23
371 45022-S5D-A00 1.00 PAD SET, FR BRAKE $32.87
372 45022-SD2-529 1.00 BRAKE PAD SET,FR DISC $29.38
373 45022-SG0-527 1.00 PAD SET, FRONT BRAKE (W517) $28.22
374 45022-SH2-A01 1.00 BRAKE PAD SET, FR DISC $29.68
375 45022-SY8-A01 1.00 PAD SET, FRONT BRAKE $31.87
376 45226-SH3-A01 2.00 CLIP A $6.66
377 45227-SD4-003 9.00 SPRING, PADS $37.17
378 45227-SH3-A01 4.00 CLIP B $13.32
379 45232-SE0-912 10.00 BOOT B, CALIPER SLEEVE $37.30
380 45233-S04-A01 4.00 BUSHING $13.76
381 45233-SE0-911 13.00 BOOT A, CALIPER SLEEVE $37.70
382 45233-SM4-A01 4.00 BUSHING $8.20
383 45234-SA5-672 7.00 BOOT, CALIPER GUIDE PIN $9.38
384 45234-SE0-911 12.00 BOOT, BRAKE CALIPER PIN $32.40
385 45234-SM4-A02 4.00 BOOT, CALIPER PIN $16.64
386 45235-SA0-671 1.00 PIN, CALIPER HOLDER $5.43
387 45235-SE0-911 1.00 CALIPER SLIDE PIN $5.00
388 45236-SA5-672 1.00 BOOT, CALIPER PIN $2.50
389 45237-SM4-A01 2.00 CLIP, PAD $5.12
390 45240-SA7-003 1.00 BOLT, CALIPER $1.72
391 46505-SA5-010 5.00 PEDAL STOP $7.20
392 46545-SA5-000 6.00 PAD, PEDAL $12.66
393 47769-06020 2.00 BUSH, CYLINDER SL $0.00
394 4PK-0780 1.00 BELT, MULTI RIB $4.69
395 500-7870 4.00 RIVET, BUMPER PLASTIC $5.00
396 501-13004 3.00 RIVET, BUMPER FRNT/REAR $3.63
397 501-1908 7.00 FASTENER $11.41
398 510-806 5.00 CABLE END $15.00
399 5210 10.00 HOSE CLAMP $3.60
400 5224 15.00 Clamp, hose $8.25
401 52387-SE0-023 2.00 BOLT, ADJUSTING RR CTRL ARM $15.42
402 53271-SM4-003 1.00 PLASTIC COUPLER $0.00
403 53434-SA0-000 1.00 CLIP BOOT $0.00
404 53521-692-003 1.00 STEERING RACK END $23.15
405 53534-SA5-951 1.00 TIE-ROD END COVER $6.97
406 53536-SB2-000 7.00 CLIP ROD END $14.77
407 53536-SP0-000 3.00 WASHER, TIE ROD LOCK $6.78
408 53546-679-004 1.00 SEAL BAL, TIE ROD END $5.67
409 53546-SH0-A01 5.00 BOOT, TIE ROD(w SA0-003 ) $19.25
410 53548-611-003 4.00 CLIP $0.00
411 53548-SA0-003 6.00 CLIP BOOT $9.66
412 53548-SD4-003 3.00 CIRCLIP, LOWER $0.00
413 53629-SA5-951 5.00 RING PISTON, STEERING $14.85
414 53629-SD4-951 7.00 RING, PISTON SEAL $24.99
415 53629-SD4-952 4.00 RING, POWER STEERING PISTON $13.24
416 53640-671-003 2.00 RING, PISTON SEAL $7.38
417 53678-671-325 3.00 SEAL KIT $45.63
418 53679-689-305 2.00 ORING SET $6.06
419 53697-SA1-951 1.00 CAP, P/S RESERVOIR $2.20
420 552 1.00 FLASHER H.D. 12V $1.07
421 565-093 4.00 BRASS EXP PLUG $5.60
422 57072-ST5-003 8.00 O-RING, ABS ACCUMULATOR $8.72
423 57202-ST5-003 9.00 SEAL, ALB ACCUMULATOR $6.12
424 57315-ST5-003 1.00 O-RING, PUMP-MODULATOR $1.82
425 6001/012Z 10.00 BEARING, DIST SHAFT $0.00
426 6204 15.00 HOSE CLAMP $12.90
427 6206 12.00 CLAMP, ATF COOLER $3.60
428 65213 10.00 HOSE, ATF COOLER $24.60
429 66405-SD 4-000 1.00 STAY $2.34
430 71910 1.00 ALIGNMENT SHIM ( 1/32 toe ) $5.49
431 71913 3.00 ALIGNMENT SHIM (5/32 toe) $13.11
432 71914 2.00 ALIGNMENT SHIM (3/16 toe) $8.74
433 71915 3.00 ALIGNMENT SHIM (1/4 toe) $10.59
434 71916 3.00 ALIGNMENT SHIM (5/16 toe) $10.59
435 71917 3.00 ALIGNMENT SHIM (3/8 toe ) $10.59
436 71918 4.00 ALIGNMENT SHIM ( 7/16 toe ) $15.16
437 71920 3.00 ALIGNMENT SHIM (1/16 camber) $10.59
438 71921 3.00 ALIGNMENT SHIM (1/8 camber) $10.59
439 71922 3.00 ALIGNMENT SHIM (1/4 toe) $12.60
440 71923 5.00 ALIGNMENT SHIM (3/8 camber) $17.65
441 71924 5.00 ALIGNMENT SHIM (1/2 camber) $21.00
442 71925 3.00 ALIGNMENT SHIM (5/8 camber) $10.59
443 71926 4.00 ALIGNMENT SHIM (3/4 camber) $14.12
444 71927 3.00 ALIGNMENT SHIM (7/8 camber) $10.59
445 71928 4.00 ALIGNMENT SHIM (1 camber) $17.48
446 72123-SR0-003 5.00 CLIP $0.00
447 72126-SM4-003ZB 2.00 SCREW CAP $0.00
448 72134-S04-003 1.00 BUSHING $1.94
449 72616-SM4-003 2.00 CLIP, DOOR LATCH $1.92
450 73146-538-000 10.00 LOCK NUT CLIP $2.60
451 74172-SE0-000 3.00 RADIATOR CUSHION (mt) $8.61
452 7440 8.00 BULB, HALOGEN (34906-) $24.80
453 7443 8.00 BULB, HALOGEN (34906-ST5-003) $26.33
454 75329-SH4-013 1.00 CLIP B, $1.83
455 75415-671-315 11.00 NOISE ELIMIN. $12.43
456 75415-SA0-300 3.00 ELIMINATOR R NOISE $2.49
457 75455-671-315 13.00 NOISE ELIMIN $13.65
458 75455-SA0-300 7.00 ELIMINATOR $5.32
459 75522-611-000 2.00 GROMMET $1.42
460 75612-611-000 2.00 CLIP, DOOR HANDLE $2.22
461 75700-SV4-000 1.00 EMBLEM $8.23
462 75760-SB2-003 2.00 PIN, DOOR $0.00
463 76622-S30-003 2.00 INSERT 527mm $6.72
464 76622-S3Y-A01 4.00 INSERT, REAR WIPER $14.32
465 76622-S50-003 1.00 INSERT, REAR WIPER 425mm $3.14
466 76622-SDA-A01 4.00 WIPER INSERT, 650MM $13.44
467 76622-SF4-305 3.00 INSERT, WIPER (w003) 500mm $9.42
468 76622-SM4-305 6.00 INSERT, W/S WIPER (w003) 600mm $18.84
469 76622-SR3-305 4.00 RUBBER 550mm $12.56
470 76632-S50-003 1.00 INSERT, WIPER $3.25
471 76732-SR3-003 1.00 WIPER INSERT $2.93
472 76810-SG0-J01 1.00 SPRAYER, WINDSHIELD $0.00
473 76810-SP0-A11ZE 1.00 NOZZLE $12.97
474 76815-SG0-A11 1.00 SPRAYER, WINDSHIELD $0.00
475 76829-SM1-004 1.00 JOINT, W/S WASHER $2.26
476 76830-SG0-023 1.00 SPRAYER, WINDSHIELD $0.00
477 76875-SM1-004 1.00 BELLOW FRT, WASHER $3.56
478 77253-611-004 7.00 SCREW $6.51
479 77508-SX0-000 1.00 ARM, GLOVE BOX $1.50
480 79371-SZ3-A01 4.00 FILTER, CABIN AIR $66.00
481 79710-SM4-A03 1.00 VALVE, HEATER CONTROL $24.16
482 80291-S84-A01 1.00 ACC CABIN FILTER SET $5.53
483 80291-ST3-505 7.00 FILTER, CABIN AIR $65.10
484 80291-ST3-E01 1.00 FILTER, CABIN AIR x $9.98
485 80292-S5A-003 1.00 FILTER, PAIR HVAC (nS5D A01) $18.01
486 80310-SE0-L01 1.00 HOSE COMP $31.34
487 80440-SM4-003 1.00 SWITCH, A/C CUTOFF $19.42
488 80490-SM4-A01 1.00 RELAY ASSY (w39798-SE0-003) $22.45
489 80865-SL0-003 3.00 CAP, A/C SERVICE VALVE R134 $9.12
490 80866-SL0-003 1.00 CAP, A/C SERVICE VALVE $4.41
491 86-1181D 1.00 BELLOWS KIT, OUTER JOINT $7.39
492 86-2133K 1.00 BELLOWS, CV JOINT KIT INNER $5.14
493 87139-32010 2.00 A/C CABIN FILTER $32.74
494 87139-47010 1.00 ACC CABIN FILTER $15.82
495 87139-50030 1.00 A/C CABIN FILTER $18.76
496 87245-32160 1.00 HOSE, WATER $18.29
497 88145-671-0032A 6.00 MIRROR BASE $0.00
498 8-94202-456-3 3.00 GROMMET, CAM COVER $1.92
499 90002-PB3-000 8.00 BOLT FLANGE, T-STAT HOUS $22.16
500 90004-671-005 8.00 BOLT $0.00
501 90007-657-920 7.00 BOLT 8X56 $13.37
502 90007-657-921 1.00 BOLT 8x70 $2.02
503 90009-PH1-000 9.00 BOLT, ENGINE OIL DRAIN $12.42
504 90009-PY3-000 2.00 OIL DRAIN PLUG $6.54
505 90011-PB2-000 2.00 BOLT, HEX (FLYWL MNT) $4.76
506 90011-PC6-000 3.00 BOLT 7X9 $3.66
507 90012-PM7-000 2.00 BOLT $0.00
508 90013-634-003 5.00 STUD $0.00
509 90013-P08-010 3.00 BOLT, HEAD COVER $6.54
510 90013-PC6-000 1.00 STUD, VALVE COVER $0.00
511 90013-PM3-000 11.00 BOLT, B VALVE COVER $22.00
512 90014-P08-000 12.00 BOLT, HEAD COVER $33.24
513 90014-PH3-010 9.00 BOLT, B $14.40
514 90014-PM3-000 4.00 BOLT, A VLV COVER $10.48
515 90017-PB2-004 5.00 BOLT $18.60
516 90029-611-000 22.00 BOLT HEX 24mm $19.14
517 9003 8.00 BULB, HALOGEN $59.76
518 9004 5.00 HEADLIGHT BULB $20.55
519 9005 4.00 BULB, HALOGEN HIGH-BEAM $35.72
520 90064-657-320 5.00 STUD $7.40
521 90065-657-330 2.00 STUD 10mm $4.84
522 90066-PC8-010 16.00 BOLT 32MM $76.00
523 90081-PB6-000 1.00 BOLT, TRANS DRAIN $3.92
524 90103-SD4-000 7.00 SCREW $9.03
525 90107-663-670 2.00 BOLT, CALIPER MOUNTING $5.66
526 90107-669-670 1.00 BOLT, CALIPER MOUNT $1.44
527 90113-SA5-020 5.00 BOLT $0.00
528 90114-SM4-000 11.00 BOLT, FRT HUB 10x20 $13.20
529 90117-693-010 3.00 BOLT-CNTRL ARM $7.26
530 90118-634-000 2.00 BOLT LOWER ARM $2.14
531 90128-693-000 4.00 BOLT WASHER 6X20 $0.00
532 90140-SA0-003 5.00 SCREW TAP $0.00
533 90140-SB0-003 6.00 SCREW TAP $0.00
534 90160-689-003 12.00 SCREW PAN 4X6 $0.00
535 90160-SB0-000 2.00 SCREW PAN, HEADLIGHT FRM 4X25 $1.78
536 90162-692-013 8.00 SCREW TAP 4X8 $7.60
537 90163-SM4-005 1.00 STUD, WHEEL MOUNTING $1.85
538 90170-S30-000 4.00 BOLT, CALIPER FLANGE $10.88
539 90178-SM4-013 2.00 BOLT, RADIUS ROD $8.62
540 90201-634-000 9.00 BOLT 20mm $25.92
541 90201-689-900 4.00 BOLT 20mm $11.24
542 90201-PB6-000 9.00 NUT 22mm $28.98
543 90202-634-020 9.00 NUT 23mm $23.67
544 90202-671-961 5.00 NUT 21mm $19.15
545 90203-PB2-000 6.00 NUT AIR CLNR $10.62
546 90214-PK2-000 6.00 BOLT, CAP $10.44
547 90216-P0A-000 4.00 NUT, 10mm $12.28
548 90217-657-000 2.00 NUT 8mm $0.86
549 90301-07001 3.00 O-RING $3.03
550 90301-07024 4.00 Seal, fuel injector $2.12
551 90301-52006 3.00 O RING, OIL COOLER $15.00
552 90301-601-020 2.00 NUT 22mm $4.08
553 90303-692-003 5.00 LOCK NUT 10mm $5.50
554 90304-634-000 6.00 NUT WHEEL MOUNT $32.94
555 90305-SD4-003 4.00 SPINDLE NUT $17.24
556 90306-SA5-003 4.00 NUT CLIP 4mm $0.00
557 90311-35022 1.00 SEAL, OIL PUMP DRIVE $2.56
558 90311-38034 1.00 CAMSHAFT SEAL $4.51
559 90311-46001 1.00 SEAL, FRONT CRANK $7.60
560 90316-659-000 6.00 NUT $11.82
561 90320-601-000 3.00 CASTLE NUT 10mm $3.00
562 90381-SE0-003 2.00 LUG NUT $7.84
563 90402-PC8-010 7.00 WASHER 32MM $12.11
564 90428-PD6-003 18.00 WASHER, SEALING $35.82
565 90441-PC6-010 6.00 GROMMET, CAM COVER $6.48
566 90441-PK2-000 5.00 GROMMET, CAM COVER $8.35
567 90441-PN4-000 7.00 WASHER, HEAD COVER nP64 $7.70
568 90441-PT0-000 16.00 WASHER, HEAD COVER $24.32
569 90442-P2A-000 5.00 GROMMET/SEAL $4.40
570 90442-P8A-A00 2.00 GROMMET, CAM COVER $4.92
571 90442-PR3-000 4.00 SEAL, CAM COVER $9.00
572 90471-PX4-000 85.00 WASHER, OIL DRAIN $48.45
573 90480-18001 1.00 GROMMET, PCV VALVE $1.95
574 90480-30025 4.00 SEAL, SPARK PLUG TUBE $6.80
575 90542-PH7-000 2.00 VLV CVR GROMMET $1.80
576 90601-S84-A01 5.00 GROM, HOOD $4.00
577 90620-SK7-013 2.00 ROD HOLDER, CLIP $0.00
578 90633-671-000 10.00 SPEEDO CLIP ( 90633-590-020 ) $7.60
579 90651-538-000 3.00 BRAKE CLIP, R CALIPER $0.00
580 90660-SB3-671 2.00 RETAINER, PLASTIC $0.00
581 90662-693-003 3.00 GROMMET S $2.22
582 90662-SA5-003 1.00 CLIP MOULDING $0.00
583 90663-SA5-003 3.00 CLIP RR APRON S $0.00
584 90665-SB0-671 5.00 CLIP, MLDG $5.70
585 90667-SA5-003 4.00 CLIP, PUSH IN $0.00
586 90667-SA7-003Z 6.00 CLIP, PUSH IN $0.00
587 90667-SB0-671 2.00 CLIP, MLDG $0.00
588 90672-SB0-003 11.00 ROD HOLDER $10.23
589 90673-692-003 5.00 CLIP FRT COWL $4.35
590 90674-SB0-000 2.00 SCREW GROMMET $2.52
591 90675-SA7-003 14.00 CLIP, FRONT $27.30
592 90677-693-003 1.00 ROD HOLDER $1.44
593 90677-SE0-003 9.00 ROD HOLDER $5.76
594 90678-SB0-000 4.00 CABLE STRAPS $0.00
595 90679-689-013 5.00 CLIP MUD FLAP $3.55
596 90679-SB2-003 2.00 CLIP, BUMPER CORNER $0.00
597 90682-671-003 2.00 SCREW GROMMET $0.00
598 90704-634-000 4.00 KEY $5.24
599 90741-657-000 1.00 KEY 25. 4X34 $1.88
600 90751-SE0-003 8.00 CLIP, PLASTIC $0.00
601 90915-YZZA1 5.00 FILTER, ENG OIL(orF1) $13.25
602 90915-YZZF2 4.00 FILTER, ENGINE OIL(wA2) $10.16
603 90917-06044 1.00 GASKET, EXHAUST $5.19
604 91003-601-000 1.00 BEARING $11.83
605 91003-657-003 1.00 BEARING $6.83
606 91004-657-961 1.00 BEARING $9.76
607 91005-657-008 1.00 BEARING (91002-PL0-018) $6.62
608 91006-634-008 2.00 BEARING $12.66
609 91048-P2A-003 1.00 BEARING $8.45
610 91048-PY3-003 1.00 BEARING, SEALED $17.76
611 91053-634-008 1.00 WHEEL BEARING $5.35
612 91201-PC1-003 2.00 SEAL,P/S PUMP (orPEO-003/4 $7.88
613 91201-PT0-003 14.00 POWER STEERING PUMP SEAL $38.50
614 91201-PW5-015 1.00 OIL SEAL $0.00
615 91203-PFB-003 5.00 OIL SEAL(wPR4004,PG6003) $17.05
616 91205-611-005 1.00 OIL SEAL $1.95
617 91205-639-005 8.00 FLANGE SEAL $19.52
618 91205-PC9-711 3.00 AXLE FLANGE SEAL (wPG1-003) $18.39
619 91205-PE6-004 5.00 OIL SEAL, AXLE FLANGE $29.55
620 91205-PL3-A01 2.00 FLANGE SEAL, LEFT $6.84
621 91205-PX5-003 2.00 SEAL, OUTPUT SHAFT $4.46
622 91206-639-005 1.00 OIL SEAL $4.13
623 91206-689-005 1.00 OIL SEAL $6.62
624 91206-PE6-003 3.00 SEAL, AXLE LFT $14.64
625 91206-PK4-003 4.00 SEAL, RIGHT AXLE FLANGE $23.48
626 91206-PK5-005 1.00 SEAL, RIGHT FLANGE $5.43
627 91206-PL3-A01 1.00 SEAL, TRANS FLANGE $3.93
628 91206-PW5-015 1.00 OIL SEAL $0.00
629 91206-PX5-005 1.00 SEAL, RIGHT FLANGE $4.10
630 91207-P0X-003 2.00 SEAL, CONVERTER SHAFT $8.86
631 91207-PG4-005 1.00 OIL SEAL $4.34
632 91208-PB6-005 6.00 SEAL, CLUTCH RELEASE ARM $10.38
633 91212-P06-A01 6.00 SEAL, FR CRANK(P06,P7A,P2F) $13.86
634 91212-P0A-004 3.00 SEAL, FRONT CRANKSHAFT (wPT0) $14.94
635 91212-PAA-A01 4.00 SEAL, FRONT CRANK $18.16
636 91212-PH1-661 1.00 OIL SEAL ( 91212-PC6-003 ) $4.59
637 91212-PH7-013 2.00 SEAL, FRONT CRANKSHAFT $12.44
638 91212-PJ5-013 2.00 SEAL, FRONT CRANK $9.50
639 91212-PR4-A01 3.00 SEAL, FRONT CRANK (PR3-003) $16.86
640 91213-P8A-A01 3.00 CAMSHAFT SEAL $11.10
641 91213-PD2-004 3.00 SEAL (was PC6-003) $6.12
642 91213-PL2-003 2.00 SEAL, FRONT CAM $10.44
643 91213-PR3-004 2.00 SEAL, FRONT CAM $7.32
644 91213-PT0-003 12.00 OIL SEAL, 28X42X $48.00
645 91213-PY3-004 2.00 CAMSHAFT SEAL $11.10
646 91214-PB2-003 4.00 OIL SEAL $33.44
647 91214-PL2-004 1.00 OIL SEAL 98X80 $11.84
648 91215-689-013 2.00 SEAL, TRANSMISSION SHIFT SHAFT $7.80
649 91216-689-003 8.00 OIL SEAL $27.20
650 91216-PA0-003 2.00 OIL SEAL ( 91216-634-003 ) $4.66
651 91216-PC8-003 1.00 OIL SEAL $2.03
652 91216-PL3-005 4.00 SEAL, OIL $9.92
653 91233-PT0-003 4.00 SEAL, BALANCE SHAFT(90acc $11.52
654 91233RETAINER 2.00 RETAINER, BAL. SHAFT SEAL $6.44
655 91249-P02-003 5.00 SEAL, PWR STG PUMP 30x30x5mm $17.25
656 91249-P0A-003 3.00 SEAL, P/S PUMP 25x25x8mm $12.00
657 91249-PY3-003 10.00 SEAL, P/S PUMP 30x30x7mm $43.30
658 91301-657-000 4.00 O-RING $14.72
659 91301-689-003 9.00 O-RING $17.46
660 91301-PJ7-000 9.00 O-RING, CAM BEARING $14.40
661 91301-PM7-003 1.00 SEAL, 7.3mmX2.2mm (wPD6-003,P2 $1.30
662 91301-PR7-A00 4.00 O-RING (wPH3-003) $6.16
663 91302-657-000 2.00 O-RING (w91309-pc6-003) $4.46
664 91302-GE0-000 2.00 SEAL, 8.8mmX1.9 $2.16
665 91302-PE0-000 20.00 O-RING 14.6 X 3 $18.40
666 91303-PM5-A02 10.00 O-RING (TBI INJECTOR) $7.20
667 91303-PT0-004 3.00 SEAL, P/S PUMP HOUSING $8.10
668 91304-PE2-005 1.00 O-RING $1.09
669 91304-PM5-A02 10.00 O-RING (INJ TBI) $19.40
670 91305-PM5-A02 5.00 O-RING (INJECTOR TBI) $12.25
671 91305-PN4-003 1.00 O-RING $3.10
672 91305-PT0-003 4.00 SEAL, P/S PLUNGER $10.80
673 91306-PT0-004 3.00 SEAL, P/S PUMP FRONT $8.10
674 91307-MB0-003 2.00 O-RING $2.28
675 91307-PE0-010 3.00 SEAL, OIL PUMP $3.51
676 91308-PB8-610 10.00 O-RING $10.10
677 91308-PK1-003 7.00 O-RING $8.75
678 91311-PH7-003 3.00 O-RING 13.8X2. $2.85
679 91312-PC6-003 3.00 O-RING $4.98
680 91312-PY3-000 3.00 SEAL, PIPE WATER BYPASS $1.23
681 91313-611-010 1.00 O-RING $1.22
682 91314-634-000 1.00 O-RING $0.53
683 91314-PH7-003 8.00 SEAL, WATER DIST. TUBE $4.24
684 91316-642-750 3.00 O-RING $1.77
685 91316-PB2-003 4.00 O-RING $3.92
686 91316-PE7-730 3.00 SEAL, 62.4X3.0mm OIL FLTR HSNG $5.25
687 91317-P02-003 7.00 O-RING, 5.21 $6.23
688 91317-PT0-003 4.00 O-RING, P/S PUMP $2.88
689 91318-PH7-003 1.00 O-RING, OF HSNG $1.64
690 91318-PH7-004 4.00 O-RING, OF HSNG $6.56
691 91318-PT0-004 2.00 0-RING, P/S PUMP (9. $1.44
692 91318-PY3-000 4.00 GASKET, FILTER BASE $26.28
693 91322-PT0-003 5.00 O-RING, P/S PUMP CASE $3.40
694 91327-PH7-003 1.00 O-RING 29X2.4 $2.80
695 91345-PAA-A01 2.00 0-RING $1.40
696 91345-PY3-000 5.00 O-RING, 23.3 $4.85
697 91346-PY3-000 6.00 O-RING, PUMP 22mm $6.18
698 91347-PY3-000 7.00 O-RING, P/S PUMP $7.35
699 91348-PY3-000 10.00 O-RING, P/S PUMP $16.90
700 91351-764-641 2.00 O-RING 59 $2.92
701 91353-SA5-951 1.00 O-RING $0.52
702 91353-SB4-952 3.00 PACKING $0.00
703 91356-671-000 2.00 O-RING 28.5MM, ST GEAR $1.52
704 91356-671-004 2.00 ORING 28.5 MM $1.52
705 91356-SD4-952 10.00 ORING, 31.5X2 $9.10
706 91370-SB3-950 3.00 O-RING, P\S OULET HOSE $2.76
707 91370-SM4-004 4.00 O-RING $5.36
708 91370-SV4-000 9.00 O-RING, 14MM $4.77
709 91501-SD2-003 6.00 HOLDER, HOOD ROD $11.88
710 91501-SM4-003 5.00 CLIP, FRONT COWL $5.50
711 91508-SM4-003 1.00 CLIP, COWL COVER $1.61
712 91523-SM4-003 4.00 CLIP $0.96
713 91534-SE0-003 9.00 CLIP, SIDE MOLDING $9.72
714 91566-SP0-003 4.00 CLIPS $6.20
715 91638-SF1-A11 12.00 CAP, VALVE A/C $0.84
716 91639-SF1-A11 6.00 CAP, VALVE A/C $5.04
717 921 3.00 BULB, TOP BRAKE $5.40
718 93500-03006-0G 20.00 SCREW $2.00
719 93600-06014-0H 4.00 SCREW $1.04
720 93600-06025-08 9.00 SCREW 6x25mm $2.70
721 93700-05012-0G 36.00 SCREW $4.32
722 93903-14580 7.00 SCREWS $0.00
723 93903-16180 10.00 SCREW $1.80
724 94109-12000 50.00 WASHER $13.00
725 94109-14000 20.00 WASHER $4.00
726 94109-20000 15.00 WASHER $4.95
727 94301-14200 12.00 DOWEL PIN $8.16
728 94305-80222 3.00 SPRING PIN 8X20 $1.83
729 95003-07008-70M 10.00 HOSE, W/S WASHER (meter) $12.50
730 95005-12003-10M 4.00 HOSE, PCV $3.32
731 95005-1211010 6.00 TUBE 12X10 $23.34
732 95700-10060-08 1.00 BOLT FLANGE $0.77
733 95700-10145-08 1.00 BOLT FLANGE 10X1 $1.53
734 95800-06070-08 6.00 BOLT FLANGE $2.82
735 96100-6001/012Z 7.00 BEARING, DISTRIBUTOR SHAFT $100.31
736 96100-6001-2NSL 13.00 BEARING, DIST SHAFT (early) $77.48
737 96140-62060-10 2.00 BALL & ROLLER BEARINGS $0.00
738 96761-24017 1.00 $0.00
739 96761-24019 4.00 SEAL, WATER PUMP $2.60
740 98200-12000 1.00 FUSE, 20A $0.00
741 98200-63500 23.00 FUSE $5.75
742 98200-65500 4.00 FUSE $1.76
743 A/C FLUSH 1.00 A/C FLUSH (520-274) $17.50
744 A/C OIL 1.00 REFRIGERANT OIL $0.81
745 A/C O-RING 1.00 MISC O-RINGS $0.10
746 A/C O-RINGS 1.00 A/C O-RING $0.36
747 AC726245 3.00 A/C RETROFIT KIT $0.00
748 ACT465 1.00 BRAKE PAD SET,CERAMIC HI-PERF $38.86
749 ACT914 1.00 BRAKE PADS, CERAMIC HI-PERF $48.13
750 ATM15 3.00 15A FUSE $0.75
751 ED18 1.00 battery tester $0.00
752 FUSE HOLDER 1.00 IN-LINE HOLDER $1.62
753 H4666 2.00 HEADLIGHT ( 33110-SB2-663AH ) $26.18
754 H6054 1.00 SEALED BEAM, HALOGEN $10.08
755 HB001/HB002 8.00 Kit, boot clamp $13.76
756 ISD465A 1.00 PAD SET, FRT HI-PERF CERAMIC $32.61
757 ISD476 1.00 PAD SET, HI-PERF CERAMIC $38.91
758 ISD537 1.00 PAD SET, REAR HI PERF CERAMIC $30.96
759 K&N CHEMICAL CLEANER 1.00 $10.00
760 K5520-01 1.00 Brake shoe set $16.37
761 KC-53006 2.00 CALIPER REBUILD KIT(KC53006) $15.86
762 KC-53007 1.00 BRAKE CALIPER KIT $0.00
763 KC-54001 1.00 CALIPER SEAL KIT (KC54001) $5.90
764 KC-54002 2.00 CALIPER REBUILD KIT (KC54002) $15.00
765 KC-54003 1.00 CALIPER REBUILD KIT (KC54003) $10.45
766 KC-54006 1.00 CALIPER REBUILDING (KC54006) $25.70
767 KC-54007 2.00 CALIPER REBUILD KIT(KC54007) $0.00
768 KC-54010 1.00 BRAKE CALIPER KIT $0.00
769 KC-70001 1.00 CALIPER REBUILDING (KC70001) $4.29
770 KC-70012 1.00 CALIPER REBUILDING (KC70012) $8.72
771 KC-70013 1.00 CALIPER SEAL KIT (KC70013) $8.79
772 M02 1.00 MOLYBDENUM GREASE $0.22
773 N480941-0010 18.00 VALVE, A/C SERVICE $21.42
Total: $10,032.43
Best offer, purchace penny's on the dollar.
Old Nov 17, 2009 | 12:12 PM
yee SERIOUS's Avatar
Default Re: 10K Honda Inventory, Anyone Interested?
Old Nov 18, 2009 | 10:45 AM
whit3jdmkid's Avatar
damn thats a lot of stuff haha
Old Nov 18, 2009 | 12:06 PM
Chef Andre's Avatar
HT's TOP CHEF
WOW!!!!
Old Nov 18, 2009 | 01:08 PM
EG6 Love's Avatar
holy **** bump
eg_bseries
Feb 9, 2016 06:32 AM
Pinche Caro
Feb 27, 2011 10:03 AM
Pinche Caro
Feb 10, 2011 01:04 PM
smoke traces
Aug 5, 2004 06:13 PM
