clutch pedal all the way down 93 prelude..
Old Nov 17, 2009 | 09:15 AM
sins's Avatar
Icon3 clutch pedal all the way down 93 prelude..
Ok so i'm driving down the road and all of a sudden the clutch pedal goes all the way down on my 93 lude 5 speed, it wont come up just sits there and the car wont go into gear..I checked all the fluids and everything was normal..It cant be the clutch cause it shifted real good with no problems and when i turn the car off it goes into every gear, so a bad clutch wouldnt have done that. My guess is that the clutch slave cylinder went out but not to sure thats why im posting this on here to see if anyone has had any similar problems or know what can be causing this...thanks
Old Nov 17, 2009 | 09:50 AM
vlude99's Avatar
Default Re: clutch pedal all the way down 93 prelude..
it's either:
1) Bad MC
2) Leak in lines somewhere
3) Air in the lines ( Bleed the clutch lines)
4) slave cylinder( but those don't go bad as easily as the MC)
Old Nov 17, 2009 | 09:57 AM
sins's Avatar
Originally Posted by vlude99
it's either:
1) Bad MC
whats MC
Old Nov 17, 2009 | 10:01 AM
crazes's Avatar
Moderator
i say master cylinder for sure. check for fluid leakage around the clutch pedal.
Old Nov 17, 2009 | 10:10 AM
jdmwannabee's Avatar
also make sure the clevis pin on your clutch pedal didn't work it's way out.
Old Nov 17, 2009 | 10:17 AM
vlude99's Avatar
^also check what he said
MC = Master Cylinder
Old Nov 17, 2009 | 11:58 AM
prelude1897's Avatar
like everyone has metioned above, either bad master cylinder or slave cylinder. Either way, I'd change both so that you only have to bleed the system once.
Old Nov 17, 2009 | 01:36 PM
crazes's Avatar
Moderator
Old Nov 17, 2009 | 02:59 PM
blklude5g's Avatar
and just to reiterate this fact - master cylinder lol - funny mine went out one me 2 days after i got mine - learning manual tranny on a **** MC FTL
Old Nov 18, 2009 | 06:39 AM
codered20102010's Avatar
New User
master cylinder, mind did that, replaced it and havnt had a problem since then.
Old Nov 18, 2009 | 02:43 PM
black94lude's Avatar
Your clutch might be out. I remembered any incident like this happen to my brother integra. It appeared that his clutch was out, we had to replaced it.......
Chev
Aug 14, 2017 02:05 PM
jonesy3737
Feb 21, 2015 07:29 AM
xxgriffonxx2
Transmission & Drivetrain
Apr 28, 2010 10:18 AM
hannslebo
Oct 8, 2009 04:44 PM
byronl
May 2, 2006 07:53 PM
