D16Z6 IM onto D15B7 question
ok, so I decided to put the intake manifold from a D16Z6 onto a D15B7 cause of the larger runners. everything went smooth until we ended up with an extra water line that originally went from the fast idle thermo valve to a nipple located on the D15B7 intake mani just underneath the larger one. the D16Z6 mani doesn't have a place to put it. so should i follow the D16Z6' map and run it from the FITV to the upper manifold nipple and just block off the one coming from the steel water pipe behind the block? i ask that only because the D16Z6 doesn't have that one from the main pipe anyway if i remember right. or should i use a T fitting and connect them all (which i really can't do at this particular time)
i think i just answered my own question. i'm thinking it would be best to use a Y fitting so i can keep the original D15B7 coolant format and merge the extra line into the cylinder head where it would be in it's original format by using that method.
metalslug
Aug 12, 2012 10:39 PM
95-Accord-EX
Sep 16, 2008 05:27 PM
