Sunroof stuck
Well I see post on this a bit but I just got a 90 si that I plan on restoring. Pretty good shape except the sunroff will not close all the way and the switch seems to not be working. The switch will buzz and slightly move each way but that is it. The other issue is on pass-side something keeping it from closing all the way. I suspect I need to just remove the whole unit and clean inspect etc. New to this site but thanks..
Where are you located?
I'm in OC, CA. I got a perfect entire sunroof bowl with everything except the exterior panel. Selling it for 120. Work 100% perfect. Let me know if you need it
InfamousRS
Mar 11, 2002 03:04 PM
