B16 IM onto GSR
Old Nov 16, 2009 | 03:58 PM
gooberguy31's Avatar
Default B16 IM onto GSR
hi, Is it possible to put a B16 Blox IM onto a GSR? Would their need to be major fabing?
Old Nov 16, 2009 | 08:24 PM
Default Re: B16 IM onto GSR
umm bump
Old Nov 17, 2009 | 07:45 AM
i would really like to know...
Old Nov 17, 2009 | 08:53 AM
aj99si's Avatar
would need to do major modifications.
Old Nov 17, 2009 | 08:58 AM
you would huh, i didn't know if since it was b series to b series if there was a major issue, thanks much.
Old Nov 20, 2009 | 05:11 PM
lunatics209's Avatar
I'm pretty sure it can be done. Dont know how though cause I never done it before. I did see a friend of mines run a gsr head with ITR manifold though.
Old Nov 20, 2009 | 07:42 PM
pakn-heat's Avatar
Jus buy one for a b16.or itr.
You'd probably have to cut the maniolf flange thingy off the gsr and get it welded onto b16 or somthin bootleg like that
Old Nov 20, 2009 | 08:50 PM
known's Avatar
just have to redrill holes, its been done before but why not sell it and just get a gsr manifold.
Old Nov 22, 2009 | 04:22 PM
well a guy wanted to trade me for some parts i have for sale so i wanted to know what had to be done, seems like it takes the time i really don't have at this moment so i'm just gonna skip the whole idea. THanks for all the input.
Old Nov 22, 2009 | 09:58 PM
B Dap's Avatar
This is why most people just go with B16 or ITR heads is because most everything fits those and the GSR head is kind of the odd man out. Major Fab. work just like they said above.
Old Nov 25, 2009 | 04:51 PM
known's Avatar
its not major fabwork lol, gsr head is great just buy a manifold for it that fits it. aebs, skunk2, blox etc plenty of options out there.
Old Nov 25, 2009 | 11:55 PM
hybrid21's Avatar
buy a skunk2 or blox manifold specifically made for a gsr?
Old Nov 27, 2009 | 02:50 PM
yoRt's Avatar
ive currently got a gsr head on my b18b1 bottom end and like the gsr head as the compression with a stock bottom end is higher than a b16/itr head would be. since i part out hondas regualarily i have several b16 intake mani's that are just sitting doing nothing so i decieded to make it fit.
it was very easy actually, you just need to get the gsr intake gasket and put that on the b16 intake mani and redrill the holes accordingly. i redrilled every whole and will also port match the intake so the flow is not messed up. one thing to note is that the coolant port on the pass of the head will not match with the b16 port as its higher so youll have to get creative there.
but it does work and only takes a few hours.
Old Nov 30, 2009 | 10:41 AM
supra-n-civic's Avatar
well its defffinatly not a bolt on procedue. the bolt pattern is very different between gsr and b16 and ls. they are all different. exhasut is all the same but intake is not
Derekhatch92
Jan 14, 2010 06:57 PM
Ak_ef9
Mar 30, 2006 03:40 AM
allmotorek8
Jul 13, 2005 03:19 PM
92HB_HB
Sep 17, 2003 04:11 PM
