2 new problems, fuel and guage and trunk
Hi again, I've run into 2 new problems with my car. I have a phantom air/fuel gauge that's installed onto the car and when I drive it's all the way into the red zone (lean). What do I need to do so it runs in the green (rich)?
Also, my trunk light on the cluster that indicates that the trunk is open stays on. Sometimes it turns off... sometimes... I make sure it shut properly, which it does just fine, it's just that the light is telling me it's open.
The trunk latch may need some adjustment.
Do you have a wideband oxygen sensor and a programmable ECU? If not, remove the A:F meter because it is useless to you and serves no purpose.
