Need Help wiring JDM Fog Lamps Switch for JDM Headlamps
I bought this switch off a fellow HT member and I need help wiring it.
I am going to attempt it tommorrow and need to know what I need to accomplish this.
There are 5 wires
1)Red with black stripe
2)Black
3)Black
4)Red with green stripe
5)Red with black stripe
Any help is appreciated.
Thanks
[Modified by JDMTEG98, 12:03 AM 9/1/2002]
There are 5 wires
2)Black
3)Black
Thanks
https://honda-tech.com/zerothread?id=105247
That should help you out. I used it wire my foglights up. I just used my old cruise control switch cuz I dont have a JDM switch.
I just did the install today. I used the schematic here: http://www.hondaautomotiveparts.com/.../16603_13.html
It is basically the same thing. One thing is that you need to swap the wire at the steering column stalk in order to make the fogs operate to US spec. That means that when you turn on the high beams, the fogs turn off. It is nothing major but is the correct wiring scheme.
jdeemseerx
Jan 28, 2007 04:34 PM
