b18c1 bearings.!?!?! help.??
Old Nov 16, 2009 | 10:01 AM
forsakenriceboy86's Avatar
Default b18c1 bearings.!?!?! help.??
been searching and looking around but haven't found much.. i thought, i had the bearing chart all figured out but i needa see what you guys say.... jus need to get the bearings square away and then i'll be set and ready to assembly my gsr.. first build so crossN my fingers that everything goes right.!
i've been working on cars for years now(auto tech) but jus never any engine work, as far as the lower block goes.. head gasket, heads and stuff but jus never and lower end..
01 gsr with 98,xxx miles..still pretty clean and not much wear so im gettN oem honda bearings. got the motor for cheap but previous owner clam that he had a spun bearing, so i jus thought i'd do a rebuilt.
block reads-"DDDDD"
connecting rods reads-"3333"(three on all connecting rods)
crankshaft readings-
"pulley crank--------->flywheel"
B 3 C 3
3 X
C 3 C 3
any help is greatly appreciated..
Old Nov 16, 2009 | 02:53 PM
Hybrid96EK's Avatar
Default Re: b18c1 bearings.!?!?! help.??
Ok. SO for rods you need
1 - Brown
2 - Green
3 - Green
4 - Green
then for mains you need
1 - Black
2 - Black
3 - Black
4 - Black
5 - Black
Anything else? I live right by Marysville and have been working on these cars since 96 if you need anything..
Old Nov 16, 2009 | 05:33 PM
Xscort's Avatar
explain this more please if you can(bearing selections), im interested in doing the same thing...my ls had a blown HG and i just wanna go ahead and rebuild..
Old Nov 16, 2009 | 06:02 PM
Hybrid96EK, thank you.! I may just have to hit you up sometimes then.. I didn’t know someone like you lived so near.! kOol…
Xscort, its a lot of reading and understanding.. but once you get it all down, its gonna be a breeze.. but a newbie like myself with engine building, im not taking a chance or “fawk it” tYpe of work. Ehehe… good choice of jus doing a rebuild.. gOod luck bRo..
cjonescrx
10
Aug 2, 2012 04:41 AM
johnls
Aug 4, 2007 10:47 PM
Ransom
Feb 21, 2007 10:14 AM
JDMJONES
Nov 29, 2004 10:10 PM
Muckman
Jul 1, 2004 01:02 PM
