Mid-Atlantic (Sales) VA, DC, and MD
DA integra thermal exhaust, sway bar, turbo stuff, p72 ecu
Old Nov 16, 2009 | 09:36 AM
netrisk032's Avatar
Default DA integra thermal exhaust, sway bar, turbo stuff, p72 ecu
hey got some parts up for grabs... would really like to not ship the body parts or exhaust... all parts are located in 17331 in south central pa... prices do not include shipping or paypal fees
90-93 integra 3 inch Thermal Exhaust - 225
90-93 integra ST rear sway bar (20mm) (will probably work on other year integras and 92-00 civics - 80
90-93 spw rear lower tower bar - 40
-OEM 92 integra white front bumper - 50
-OEM 92 integra white hood - 50
-OEM 92 integra black fenders - 20 Each
-ebay 1pcs headlights with mercedes HIDs units for 90-93 integra - 120
-autometer Phantom series 5in tach with shift light - 60
p28 ex/si harness with the resistor box already wired in. just need to throw in on the motor and plug into the ecu. looking to get $100 obo for this
95 si transmission with unknown mileage. has a grind at high rpm going into 3rd gear. for those who dont know. the si has the same gearing as the ex but a shorter 5th gear. $150
ghetto D from HMT a/c and p/s log manifold - is cracked and has been rewelded. meant for the use of an external wastegate. dump tube will be included. only need to use slim fans for it to retain a/c can use any t3 or t3/t04b and it will be fine, will not except larger framed turbos - $80
Turbonetics Super V trim t3/t04b .50/.48 with a 5 bolt stage 2 exhaust side - Turbo has some side to side and some slight in and out but never gave me problems with holding boost at all or even with it scraping the compressor housing. would every once in awhile burn some oil slightly on start up but after the car warmed up with would no longer burn oil think it might just be an oil seal if that. was told it was ball bearing due to the anodized blue backing plate but i really have no idea if it was or not. would produce a full 9 psi by 4200 on my vitara d16z6. $250
crome chipped p72 - $100
the best way to get ahold of me is through pms or my email: tlawrenc08@gmail.com
Old Nov 19, 2009 | 09:24 AM
netrisk032's Avatar
Default Re: DA integra thermal exhaust, sway bar, turbo stuff, p72 ecu
bump
Old Nov 24, 2009 | 10:40 AM
netrisk032's Avatar
bump
netrisk032
Northeast (Sales)
Dec 25, 2009 04:33 PM
netrisk032
Nov 24, 2009 10:40 AM
netrisk032
Oct 22, 2009 10:21 AM
trooper0641
Feb 9, 2005 03:46 AM
