FS: B-series ITR swap - fresh rebuild, Exedy, Findanza, CTR, Hondata, P28, etc
SOLD SOLD SOLD SOLD SOLD SOLD SOLD
I've got a '96-spec ITR swap for sale in Alabama. The head was freshly rebuilt in the spring and I've only put 2,000 miles on the motor since reassembling it. All gaskets have been replaced, new head gasket, timing belt maintenance, etc.
This sale is just for the motor/trans/linkage/ecu, it does not include a header or engine harness. I do not have a stock exhaust manifold or engine harness for the motor, but my ANR header and ChaseBays CM1 harness can be had for an extra charge
Motor will come with driver/passenger/rear mount brackets. Also has all sensors and a new IACV
Anything from the pic below can also be added at an extra charge
Price - SOLD
96 spec ITR swap, freshly rebuilt stock
New valve seals
3-angle valve job
All new gaskets
New OEM headgasket
New timing belt, tensioner
New water pump
New distributor
New NGK plugs and wires
Hondata IM gasket
Polished 00 SI fuel rail
OBD2 injectors
96-spec ITR LSD trans - perfect, no grinds (stamp came off while cleaning )
Exedy Racing Stg 2 clutch
Fidanza 7.5-lb flywheel
CTR N1 crank pulley
P28 tuned w/Crome
MFactory magnetic oil pan and trans drain plugs
ITR "gold" shift linkage
ITR shifter
ES Shifter bushings
Unknown VTEC solenoid cover
JDM ITR oil cap
Price - SOLD
New valve seals
3-angle valve job
All new gaskets
New OEM headgasket
New water pump
New distributor
Hondata IM gasket
OBD2 injectors
CTR N1 crank pulley
P28 tuned w/Crome
ITR shifter
ES Shifter bushings
JDM ITR oil cap
92turboDA
Mar 16, 2010 07:16 AM
92turboDA
Southeast (Sales)
55
Mar 8, 2010 06:37 AM
Brewer
Nov 19, 2009 06:35 AM
g2_teg_
Mid-Atlantic (Sales)
112
Jan 1, 2008 05:55 PM
g2_teg_
Jan 1, 2008 05:54 PM
