FS: B-series ITR swap - fresh rebuild, Exedy, Findanza, CTR, Hondata, P28, etc
Old Nov 16, 2009 | 04:27 AM
Brewer's Avatar
Default FS: B-series ITR swap - fresh rebuild, Exedy, Findanza, CTR, Hondata, P28, etc
SOLD SOLD SOLD SOLD SOLD SOLD SOLD
I've got a '96-spec ITR swap for sale in Alabama. The head was freshly rebuilt in the spring and I've only put 2,000 miles on the motor since reassembling it. All gaskets have been replaced, new head gasket, timing belt maintenance, etc.
This sale is just for the motor/trans/linkage/ecu, it does not include a header or engine harness. I do not have a stock exhaust manifold or engine harness for the motor, but my ANR header and ChaseBays CM1 harness can be had for an extra charge
Motor will come with driver/passenger/rear mount brackets. Also has all sensors and a new IACV
Anything from the pic below can also be added at an extra charge
Price - SOLD
96 spec ITR swap, freshly rebuilt stock
New valve seals
3-angle valve job
All new gaskets
New OEM headgasket
New timing belt, tensioner
New water pump
New distributor
New NGK plugs and wires
Hondata IM gasket
Polished 00 SI fuel rail
OBD2 injectors
96-spec ITR LSD trans - perfect, no grinds (stamp came off while cleaning )
Exedy Racing Stg 2 clutch
Fidanza 7.5-lb flywheel
CTR N1 crank pulley
P28 tuned w/Crome
MFactory magnetic oil pan and trans drain plugs
ITR "gold" shift linkage
ITR shifter
ES Shifter bushings
Unknown VTEC solenoid cover
JDM ITR oil cap
Old Nov 16, 2009 | 05:07 AM
BakedCookies's Avatar
Default Re: FS: B-series ITR swap - fresh rebuild, Exedy, Findanza, CTR, Hondata, P28, etc
bump for a clean motor
Old Nov 16, 2009 | 08:51 AM
Brewer's Avatar
Thanks Chris
Old Nov 16, 2009 | 05:43 PM
Brewer's Avatar
PMs replied
Old Nov 16, 2009 | 07:45 PM
Brewer's Avatar
Bump
Old Nov 17, 2009 | 07:43 AM
Brewer's Avatar
Pms replied
Old Nov 17, 2009 | 10:16 AM
JDMADD1CT's Avatar
bump for a clean motor & a good deal. & im still tempted on your shell
Old Nov 17, 2009 | 10:36 AM
EJ8freek's Avatar
Bump. Wish I had a car to put that in.
Old Nov 17, 2009 | 11:03 AM
ALLxMOTOR EG's Avatar
Vietnamese!
Very clean motor, GLWS.
Old Nov 17, 2009 | 02:52 PM
Brewer's Avatar
Thanks guys
Old Nov 17, 2009 | 02:57 PM
DaveSI99's Avatar
Very clean motor and nice price too....GLWS!!!
Free bump
Old Nov 17, 2009 | 05:29 PM
Brewer's Avatar
Thank you sir, bump!
Old Nov 17, 2009 | 07:55 PM
Brewer's Avatar
Bedtime bump
Old Nov 18, 2009 | 05:12 AM
Brewer's Avatar
Morning bump!
Old Nov 18, 2009 | 09:40 AM
Brewer's Avatar
Lunch bump
Old Nov 18, 2009 | 05:07 PM
Brewer's Avatar
Back up
Old Nov 19, 2009 | 06:35 AM
Brewer's Avatar
Bump
92turboDA
Southeast (Sales)
55
Mar 8, 2010 06:37 AM
g2_teg_
Mid-Atlantic (Sales)
112
Jan 1, 2008 05:55 PM
