vss code 17 but speedo works fine?
Old Nov 16, 2009 | 03:58 AM
ejvtec's Avatar
Default vss code 17 but speedo works fine?
hey guys, my 1995 accord ex sedan 2.2L vtec (5 speed) is throwing a code 17 for the vss, but the speedo is fine..any thoughts on what could be going on?
Old Nov 16, 2009 | 03:09 PM
92civlude's Avatar
Default Re: vss code 17 but speedo works fine?
The VSS signal runs through a splice in the harness. The splice is probably loose. Instead of untapeing the harness. By-pass the "open". Tap into the wire at the speedometer and run a separate wire directly to the ECU at the VSS input.
Old Nov 17, 2009 | 10:43 AM
craiger28's Avatar
ejvtec, I am having the same problem only my speedo doesn't work at all. I don't think I would by-pass the wire to the speedo to the ecu though. I have checked all my wiring for wear or a break and found nothing??? I am beginning to believe that I have a ecu problem on my car....
Old Nov 17, 2009 | 10:51 AM
92civlude's Avatar
Well, You could run the by-pass as a temp test
Old Nov 18, 2009 | 05:58 AM
ejvtec's Avatar
if youve got a code 17, and the speedo isnt working, more than likely its your vss on the tranny (under the intake just below the throttle body...tons of posts about this, read up to figure out how to replace...
nevermind guys, my code is gone...weird...
Old Nov 22, 2009 | 11:41 AM
jmccalip's Avatar
Just replace the VSS under the intake. It will go bad pretty soon if it's having problems, mine was the same way. The part only cost $20, and only took 20 minutes to replace. All you need is a screwdriver, 12mm socket, and 20" of extensions.
singlecamsaint
Sep 30, 2011 03:46 PM
pdiggitydogg
39
Sep 3, 2007 10:44 AM
jakscivic
12
May 27, 2007 06:51 AM
dthug
Aug 17, 2006 11:29 AM
