tech question. h22 crank diffrence?
Old Nov 16, 2009 | 03:18 AM
Y2K Si FBP's Avatar
Default tech question. h22 crank diffrence?
wanted to ask the prelude guru's about a jdm h22. i would assume usdm would be the same.
is there any diffrence in cranks from a automatic and manual transmission h22a engine 1992-1996?
the engine that i used the crank from had a manual trans/clutch attached to it.
reason why i ask is this. i am running a h2b setup in my civic. where this had occured. yes the entire rotating assy was balanced at the machine shop. and it was all torqued to honda oem spec. while sampling some information that i cannot confirm possibly there is a variance/diffrence in h22 cranks? can anyone help/confirm? thanks. any help is appreciated!
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/piston-valve-clearance-semi-built-h22-mahle-2677495/
flywheel adapter
block
flywheel
Old Nov 16, 2009 | 06:03 AM
Rosko's Avatar
Default Re: tech question. h22 crank diffrence?
The cranks would be the same for those particular years.
Old Nov 16, 2009 | 06:08 AM
Y2K Si FBP's Avatar
Originally Posted by PirateMcFred
1992 (JDM) and 1993 has a fine pitch crank pulley bolt and 50mm main bearing journals.
1994-1997 has a coarse pitch crank pulley bolt and 50mm main bearing journals.
1998-2001 has a coarse pitch crank pulley bolt and 55mm main bearing journals.
Cross referencing part numbers from someplace like www.hondapartsdeals.com or a local dealership parts department should show the same info.
thank for responses. after i posted. realized there was no usdm auto h22 til 97
does anyone have access to japanese part numbers to cross referrence? so those 92-93 and 94-97 should be the same other than crank pulley bolt?
Old Nov 16, 2009 | 07:45 AM
Rosko's Avatar
Yes, and as far as I have ever know all H22's are the same on the flywhel end of the crank.
Old Jan 16, 2012 | 11:31 AM
Lude@Heart's Avatar
Bringing this back for others to see. I had this issue too. ARP hardware is too long if a shim is not used.
Automatic tranny flexplate shim works .
Old Jan 16, 2012 | 11:54 AM
balbowskie's Avatar
I actually think they maybe a differance in the crank of a auto and a manual. Only differance being the end of the crank where the flywheel bolts is a thicker end on the auto trans. I would check this thickness before I made any purchases
Old Jan 17, 2012 | 12:01 PM
dblair's Avatar
I believe the '98 up pulley bolt was also longer. Always speculated that it might be a response to spun crank pulleys on the earlier motors.
Yield
Aug 26, 2006 07:20 PM
RA062424
Jul 20, 2005 08:47 AM
97grnlude
May 25, 2003 03:26 PM
Globalundrground
Mar 12, 2003 03:49 PM
