f22 head question
Old Nov 15, 2009 | 06:39 PM
red50's Avatar
Default f22 head question
lookin to shave down my v tec head wondering if any one has done this how much have they taken off? i want to still run pump gas, wondering if any one has done any thing like this, any help is appriciated
Old Nov 16, 2009 | 03:54 AM
alterdcreations's Avatar
Default Re: f22 head question
.030
Old Nov 16, 2009 | 05:28 AM
bigsnorlax's Avatar
shaving your head wont drastically increase your compression ratio so you'll still be able to run pump gas. And .030 is the maximum u can do it, but if you do that much u might want to check for clearences ( piston to valves ). You will also need to get and adjustable cam gear to adjust for change
Old Nov 16, 2009 | 08:27 AM
hondamark35's Avatar
it may make more sense to raise compression like many others do and get some higher comp. pistons and/or flat face valves.
you'll still be able to run pump gas (if you get the right pistons), just don't skip the tune.
imnike9000
Apr 5, 2010 02:45 PM
Manny86
May 10, 2008 11:21 PM
sikcrx80
Nov 4, 2003 10:33 AM
X2BOARD
Apr 23, 2002 04:54 AM
EVOCELICA
Jul 9, 2001 04:34 PM
