WTB:B16C1 Long Block
hey guys i'm looking to buy a B18C1 longblock to swap into my LS i live in upstate NY now but am moving to Orlando, FL in Jan. so if you have one and want to sell it om me or e-mail me at chopperguy572@aol.com
oops srry i put 16 in the title instead of 18!
Ill sell you my spare built b18c-1 n.a motor! im gonna rebuild my original motor laying in my garage to low comp. real soon! i will work with shipping as much as i can!
I can do two things! sell the motor as is for $1,600! the 98'' gsr head installed on this motor is fresh from the machine shop with 0 miles! and is built with a brand new after market valve train! or i can pull the head off and install another fresh 95'' gsr head i have for sale on top of the block it will have 0 miles on the head also but will have a stock valve train for $1,300!, heres the specs!
buy it as is for $1,600! has aprox 10,000k on the block! nothing wrong and runs verry strong! thats like 4 oil changes! on the block! i baught this block fresh not to long ago for $1,300!! as a spare motor! these are the pics of the block! no short cuts were taken this was my personal motor, was built with all new oem gaskets when assembled never raced and was babied after the motor was tuned at church automotive made 216 hp! i currently had the time to pull the head and have it freshened up! it will include,
b18c-1 block complete minus dizzy! 10,000k since rebuilt!
king race bearings
new usdm itr pistons
honed and bored over.25
polished and balanced crank
arp head studs
gready timing belt! 10,000k
new oem! water pump 10,000k
new oem! itr oil pump 10,000k
98'' gsr head! has
3 angle valve job
oem valve seals
brand new!! rocket motor dual valve springs and titainium retainers!!
low milage rocker arms and lma's!
new!! suppertech high comp. flat valves!
hondata intake manifold gasket
hondata throtle body gasket
mfactory magnetic oil drain plugs
ngk spark plugs
ngk spark plug wires
stock intake manifold, cams,injectors, throtle body,short ram intake
gloss black valve cover
**$$** Or for $1,300! *note! remember i recently paid $1,300 for the block alone!!! i can have a fresh gsr head installed on the block comes with 3 angle valve job, valves regrinded, head is resurfaced not milled! all new oem gasket set installed! from the valve seals to injector o rings to the cam seals ect.., hot tanked, lubed fresh from the machine shop it has stock valve springs and retainers i will install a new head gasket and adjust the valve lash so the motor will be ready to start!
king race bearings
arp head studs
98'' gsr head! has
3 angle valve job
oem valve seals
ngk spark plugs
Thanks this is all testing waters! this motor is legit and runs great and sits in my gsr sleaper, iv built other built motors and sold them here along with countless other parts and have many vouches! and you can be asure the motors is in spec cause i go through the entire motor twice and check all clearences and torque when i build the b series motor! when you get this motor the head will have 0 miles! and i can have dig. pics of the assembly available.
wunfstgsr
Dec 15, 2009 02:24 AM
92EG8
12
Apr 30, 2008 04:30 PM
