98-02 suspension question?!?
I recently just got an alignment after lowering my car a couple of weeks ago but I forgot to cut the front bump stops. If I were to take the suspension out to cut the bump stops will that screw up my alignment? Or it only will if I changed my suspension setup again? Thanks!
nah, you'll be fine. Without having a camber kit of any kind, the only thing that can be adjusted is toe, and since that was done, it should be fine.
I pull my struts off all the time and have never had any alignment issues as a result.
Ok cool good thing! Thanks for your reposnse!
preludedriva
Jun 23, 2008 11:00 PM
