Suspension & Brakes Theory, alignment, spring rates....
trying to figure sway bars out, need some help please.....
Old Nov 15, 2009 | 01:12 PM
griffinjr123's Avatar
Default trying to figure sway bars out, need some help please.....
So i have been searching on here about sway bars. I have a 95 dx an was planning to use a teg setup, but now i was offered a new eibach sway bar kit for my car for $150. So or course im gonna get it but my ? is that since my car does not have factory sway bars what do i need to do for the install....drill/tap holes etc? An also i was planning for a teg rear disc conversion....can i still do that?
Old Nov 15, 2009 | 01:23 PM
Default Re: trying to figure sway bars out, need some help please.....
i was looking into doing front an rear skunk2 lca will that solve my problems on having somewhere to install them?
Old Nov 15, 2009 | 02:04 PM
hypd23's Avatar
you can get si from control arms to run front sway
Old Nov 16, 2009 | 03:46 AM
92-95 si? what about doing the rear?
Old Nov 16, 2009 | 03:58 AM
vgalione's Avatar
in the rear get any rear sway bar from a ex or si def cheaper to buy a set of blox rear control arms there 100 shipped front use ex or si control arms or use the teggy ones
Old Nov 16, 2009 | 05:30 AM
juall's Avatar
not 100% sure but if you get the aftermarket sway bars for the dx i think they hook up on the strut lower bolt. worth looking into for sure.
Old Nov 16, 2009 | 02:53 PM
will the 00 si's fit? how are the blox lca compared to the skunk2?
HustonB
13
Jan 3, 2013 11:36 AM
1991ED6
Sep 29, 2012 01:53 PM
crxsleeper210
Suspension & Brakes
May 4, 2006 01:27 PM
jtl
Apr 1, 2004 04:24 PM
TreDEE
Sep 30, 2001 11:49 PM
