Transmission & Drivetrain Gearboxes, Differentials, Clutches
ratio and meshing issues w/ hybrid B trans
Old Nov 15, 2009 | 09:48 AM
xzodiackillerx's Avatar
Default ratio and meshing issues w/ hybrid B trans
I am building a B series trans out of 3 broken ones..
so far I have it mocked up and the issue is the gear ratios I end up with are OK on 1-3 but 4th and 5th are weird
counter shaft / main shaft = ratio
1st 42t / 13t = 3.23
2nd 40t / 19t = 2.105
3rd 35t / 24t = 1.458
here is what fits and meshes well
CS / MS = R
4th 31t / 30t = 1.033
5th 28t / 35t = .8
what I wanted but doesn't mesh well
CS / MS = R
4th 31t / 28t = 1.107
5th 25t / 35t = .714
my FD is 15t on CS and 66 on ring gear for a ratio of 4.4 this is good and meshes . the only problem I have is 4th and 5th. would they mesh if they were in both halves of the case? or is something off?
Old Nov 15, 2009 | 10:12 AM
Honda Bull's Avatar
Default Re: ratio and meshing issues w/ hybrid B trans
The 1-3 is all B16/CTR/US ITR ratios.
CS / MS = R
5th 28t / 35t = .8
4th is B16 countershaft and LS mainshaft. 5th is B16 cs and LS ms. DO NOT USE THESE TOGETHER. They do not fit and you will have issues. And if for whatever reason that the LS mainshaft gear does work with this, it will not work with the B16 3rd gear setup you have. The LS utilizes a different 3-4 gear/synchro setup than the B-series VTEC transmissions.
CS / MS = R
4th is a B16/CTR/US ITR ratio and tooth count. 5th is an LS ratio and tooth count. They should work just fine. Do you have your numbers mixed up perhaps with the ones you wanted and the ones that work???
Also, do all of the trans guys in here a favor and do not mix and match gearsets that were not used together. lol It will not end well for your trans in all likelihood and cause you more issues in the future.
What is actually wrong/broken with all three transmissions? I'd recommend fixing one that you want and just keeping it.
Old Nov 15, 2009 | 10:38 AM
solved ... the main shaft I put in had a 20t second gear making the others not line up .. replaced with the proper 19t main shaft and things went together very nice.. all gears have proper clearance and mesh like factory.
I had a B16 trans that had a Viscous LSD in it that took a crap. the ring gear and LSD are not the same as others in the B series fam. so I had to search for a ring gear and CS that would fit in the trans . I first bought a LS trans that had a broken case and a whole set of syncros for $50 and I planed on using the LS CS and Diff but things wouldnt work for some reason .I found a GSR CS and Ring gear and OEM ITR LSD that I got from a friend. so at this point I have gears and shafts laying all over the place .. the LS 5th is so I dont have to rev too high on the Hwy. would I be better off runing a B16 5th its going on a B20vtec in a civic
Old Nov 15, 2009 | 07:07 PM
can the teeth on the sliders be reshaped to engage better than the rounded ones on them now or should I just get a new 3/4 slider kit?
Old Nov 16, 2009 | 12:46 AM
Mista Bone's Avatar
D Tranny Guru
new 3-4 slider/hub/synchro kit.....B's like to eat them.
Old Nov 16, 2009 | 02:26 PM
that sucks... I will have more wrapped up in this trans than if I bought a new one!
Old Nov 16, 2009 | 08:21 PM
Honda Bull's Avatar
Yeah, unless you magically find a cost effective way to add material to the sleeve and/or hub and remachine them, you're beat. Get a new set. It's about $280 or so for the 3-4 complete set.
dc4teg95
Jul 8, 2014 07:23 AM
blazzer
Jan 3, 2014 04:41 PM
rx191
Apr 7, 2012 02:50 PM
ground_shaking
Jan 24, 2010 08:19 PM
fourthgenhatchB17
Feb 17, 2009 12:47 PM
