Rocker arm click
Old Nov 15, 2009 | 09:13 AM
AnthonyG1990's Avatar
New User
Default Rocker arm click
I have a D16Y8 motor and have been having some issues with it. There is a ticking noise coming from the engine and initially I thought it was a valve problem but after doing compression tests have ruled that out. After doing some reasearch I figured it was some worn LMA's (Loss motion assemblies) so I replaced all 4 and that didn't solve the problem. So I took off the valve cover and starter it up and narrowed the noise down to a single rocker arm. When I push the rocker arm to the left (towards the passenger side) the noise totally goes away. So would that be a bent rocker arm? Or a worn down spacer. I have attached a picture so you can see what I'm talking about.
http://img697.imageshack.us/img697/5986/cimg0209.jpg
Old Nov 15, 2009 | 08:26 PM
mrharmonic's Avatar
Default Re: Rocker arm click
try a vlave adjustment helped me out
Tealmist
Sep 8, 2017 07:22 AM
bandit67
Feb 23, 2012 04:19 AM
hadehatch
Aug 20, 2008 10:14 AM
defaced
Dec 31, 2003 10:23 AM
drjondurst
May 5, 2003 07:11 PM
