2001 Accord Automatic Transmission buzzes after motor swap
Old Nov 15, 2009 | 06:46 AM
clemsoncb7's Avatar
Default 2001 Accord Automatic Transmission buzzes after motor swap
Hey all,
I just finished swapping another f23a4 into my 2001 Honda Accord ex because of a porous block. Anyways, everything went relatively smoothly with the swap except for something with the transmission. I filled it back up with fluid correctly however it seems when the car is under load (accel and decel), it makes a buzzing/whining noise. At first I thought it was something like a fender liner being loose or something but I deducted that because when you bump the car into neutral, the noise goes away. Anyways, any help would be greatly appreciated. Thanks in advance
Max
Old Nov 15, 2009 | 07:58 AM
clemsoncb7's Avatar
Default Re: 2001 Accord Automatic Transmission buzzes after motor swap
And just as a sidenote if it helps, The drivers inner cv separated on me while I was pulling the motor so I had to put that back together. However I was always under the impression that a bad cv would click....
Max
Jasontrammell
Apr 10, 2018 04:52 AM
fluturm
Jan 24, 2011 09:18 AM
BlueRex1020
Nov 27, 2010 11:49 AM
clemsoncb7
Transmission & Drivetrain
Nov 15, 2009 07:58 AM
