CTR intake cam gsr ehxuast cam cam gears?
I just picked up a ctr intake cam going to be running that with a gsr exhaust cam in my b18c1, is it even worth it to get aftermarket cam gears im on a tight budget. If so how well do blox or black works cam gears hold up and how accurate are the markings? if i should run cam gears what ones would you suggest? heard good things about the golden eagle but the 4 bolt design scares me.
I don't think you would need cam gears if your on a tight budget. If you do decide to get some cam gears if your choices are blox or blackworks I would recommend Blox cam gears.
hope this helps you!
Sorry but do not BUY BLOX CAM GEARS. When I had a ctr intake cam I also bought a set of blox cam gears before I wen't to tune. The cam gears came with the markings off and I had to align it with my stock cam gears to get my timing right. I'd recommend Mfactory or skunk2. BTW I only made 159whp with skunk2 IM, a 3" CAI velocity stack, JDM ITR header, 2.5" straight pipe to 2.5" exhaust. It was such a shitty tune though and I was hella pissed at the tuner because I paid 350 for a flat rate tune and he only did a base line run for my A/F ratio. He did like 4 runs then he said that's it.
I would think a Type R intake cam would do just fine. I guess it depends on what goal you're trying to reach and what you're already using on your setup.
thanks for the heads up, was the 159whp with the ctr cam?
I think its possible. I had a gsr with ctr intake and exhaust cams, aem 3in. Cai, skunk2 manifold and dc headers with a B16 tranny and I dyno at 168.
