Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Dyno results 08 SI
Old Nov 14, 2009 | 05:50 PM
kartman5's Avatar
Default Dyno results 08 SI
*Graph Now Up*
Just had my car dynoed at Churches. Very happy with the results and the car drives great.
I will post the graph soon. Throttle response is much improved!
MODS:
RRC IM
TBS
K&N drop in filter
Vibrant cat-less RH
HKS Sport TI cat back exhaust
Flash - Pro
Redline readjusted to 8600 RPM
Vtec readjusted to 4800 RPM
Old Nov 14, 2009 | 06:10 PM
nvynuke18's Avatar
Default Re: Dyno results 08 SI
not bad, about 40hp with simple bolt ons and retune. interested to see the graph for the power band
Old Nov 14, 2009 | 06:28 PM
ajpturbopittsburgh's Avatar
What kind of dyno?
Old Nov 14, 2009 | 06:40 PM
i-VTEC_DOHC's Avatar
church's uses the dynapack.
where they take the wheels off and attach the adapters to the hub.
i need a new filter for my stock intake, i just checked it out today and its
extremely dusty and filthy
Old Nov 14, 2009 | 06:57 PM
kartman5's Avatar
Will get graph up soon. Biggest gain was midrange torque, between 5000 and 7000 RPM.
Old Nov 15, 2009 | 02:33 AM
dirtySOHC's's Avatar
nice.
still amazes me that we can make this much power with bolt ons.
Old Nov 15, 2009 | 03:06 AM
Y2K Si FBP's Avatar
was astonished at the numbers..then read a dynapack.
169 ft lbs is wow.
bah to such a diffrence in dynos.
bet that si feels strong tho..great numbers! it's tuned...feels good all that matters!
Old Nov 15, 2009 | 06:57 AM
kartman5's Avatar
Thanks. It's like driving another car. The new found torque makes a big difference and I was able to also get rid of the CEL from not having a CAT. The guys at Churches really do a great job.
Old Nov 15, 2009 | 08:02 AM
larryjha's Avatar
New User
Default Looking for type R tranny
Ia am looking for a integra type r Tranny
Old Nov 15, 2009 | 08:11 AM
lucelukeEH2's Avatar
WOW...more reason than evar to get ahold of an FG2!
Wicked.
Old Nov 16, 2009 | 08:43 AM
Nexx's Avatar
Default Re: Looking for type R tranny
1-4 is identical to the SI. Only real difference is the Final Drive @ 5.062 vs 4.764.
http://www.k20a.org/forum/showthread.php?t=6395
Old Nov 16, 2009 | 01:26 PM
vollrathian's Avatar
dam great numbers, get some kind of intake and make another 5hp
Old Nov 17, 2009 | 07:01 AM
S2Carbonworks's Avatar
+1
Old Nov 19, 2009 | 09:20 PM
Wazup's Avatar
What's an RRC intake manifold? and does all the smog stuff hook up to it?
nice numbers!
Old Nov 19, 2009 | 10:23 PM
Kidnkorner's Avatar
The RRC is the 2007+ Civic Type R intake manifold, and it's 100% bolt on for the 2006+ Civic Si. All sensors swap right over.
Don't you mean 1-3? 4-6 are shorter on the ITR.
Old Nov 20, 2009 | 12:50 AM
invsta's Avatar
Old Nov 20, 2009 | 02:54 PM
ChargedSI's Avatar
MODS:
RRC IM
TBS
K&N drop in filter
Vibrant cat-less RH
Flash - Pro
227.5 HP
169.1 lbs torque
I suggest you be careful with the higher Redline. The block is balanced to 10,000rpm, but the valve train is not. I was advised against increasing my Redline without changing out my springs and retainers. Just a thought I would pass this along.
Congrats on the numbers, they look good.
Old Nov 20, 2009 | 03:01 PM
Who advised you of this?
I bet even HONDATA is being conservative when they modified the redline to 8600 with their original reflash
Old Nov 20, 2009 | 04:01 PM
i dont think they're being too conservative. 8600 rpm is when the oil pump loses efficiency. so setting the redline to 8600, would just make sure the motor doesnt lose any efficiency in lubrication. but that doesnt mean the wear and tear aspect is covered also.
Old Nov 20, 2009 | 04:20 PM
crx(gator)'s Avatar
take your numbers and take off 20% due to church's dyno reading retarded high.
Old Nov 20, 2009 | 04:50 PM
Now get you some good rubber to lay the power down with
Old Nov 20, 2009 | 04:57 PM
SergEK's Avatar
20%? Its a hub dyno that SHOULD read about 5% higher which is about what it reads...no where near 20%
Unless you think with ALL those mods the kid only makes 180whp with a K series...seriously
It should be about 212-215whp on a 248c dyno jet with those numbers....hardly "retarded high" for his mods
Old Nov 21, 2009 | 01:16 AM
invsta's Avatar
Are you suggesting our engines can rev safely at 10k and up?
Old Nov 21, 2009 | 03:00 AM
^ Is that what I said
Old Nov 21, 2009 | 10:54 AM
he said nothing of the sort.
read my post which is about 6 or 7 up from this one.
