High performance drag ERL H22 block partout
Old Nov 14, 2009 | 11:10 AM
97_Built's Avatar
Default High performance drag ERL H22 block partout
Found out that my new ERL block had a fine crack under #2 and #3 sleeves. ERL wont warranty the block, go figures, so I decided to part out the internals. Gettin a new complete block so these parts need to go soon. All parts have less than 5k miles and were run on a mild low compression N/A setup only. No parts have seen forced induction or nitrous.
NEW ITEM!!!
1. H22 Crank- Knife-edged and Balanced by Endyn. Still got the papers. All this needs is the journals micro-polished. Great part but I've got another build in mind. $400
2. Full set of Wiseco 89.5mm bore, 9:1 compression ratio, forged pistons. These are in excellent shape and would be perfect for high boost applications. These go for $675+ on horsepowerfreaks.com. $400
3. Crower Billet Steel Connecting Rods. (NOT ECONO)
These are serious rods with strength to operate with 800+whp applications. Can be used with high compression or forced induction. 3 are in excellent shape. One however suffered from a rolled rod bearing and needs to be repaired or replaced. These go for over $750 for a complete set on horsepowerfreaks.com.$400
Willing to trade one set of the above or my set of Skunk2 Tuner 2 cams for a set of Skunk2 Pro 1 cams.
Old Nov 15, 2009 | 06:58 PM
97_Built's Avatar
Default Re: High performance drag ERL H22 block partout
Bump
Old Nov 15, 2009 | 07:10 PM
Fibercation's Avatar
same set up im going with exactly...gl on the sale
Old Nov 15, 2009 | 08:30 PM
97_Built's Avatar
Thanks. These really are great parts for a high boost turbo build.
Old Nov 16, 2009 | 12:15 PM
97_Built's Avatar
Bump
Old Nov 19, 2009 | 07:27 AM
97_Built's Avatar
Bump
Old Nov 19, 2009 | 04:03 PM
97_Built's Avatar
Bump
Old Nov 19, 2009 | 04:30 PM
guy in the wtb section is looking for a sleeved block
Old Nov 19, 2009 | 04:36 PM
97_Built's Avatar
Yeah but I think he's looking for one thats not cracked lol.
Old Nov 20, 2009 | 11:04 AM
97_Built's Avatar
Bump
Old Nov 20, 2009 | 11:55 AM
Black-Ty [EG6]'s Avatar
bump
Old Nov 20, 2009 | 12:05 PM
97_Built's Avatar
Originally Posted by Black-Ty [EG6]
bump
Thanks!
Old Nov 21, 2009 | 04:11 AM
97_Built's Avatar
Bump
Old Nov 27, 2009 | 01:15 PM
97_Built's Avatar
bump
Old Dec 11, 2009 | 11:55 AM
97_Built's Avatar
Bump
Old Dec 15, 2009 | 02:07 PM
97_Built's Avatar
Bump
Old Dec 17, 2009 | 09:51 PM
97_Built's Avatar
Bump
Old Dec 29, 2009 | 04:17 PM
97_Built's Avatar
Bump. Added the knife-edged crank to the list.
Old Jan 9, 2010 | 01:42 PM
97_Built's Avatar
Bump
Blacksi76
Mar 7, 2011 10:02 AM
michaelprice83
Feb 1, 2009 07:27 AM
wrx'n you
May 28, 2006 08:49 AM
three6t
Dec 22, 2004 11:25 AM
kwik93si
Apr 2, 2003 02:16 PM
