another broken lca bolt
Old Nov 13, 2009 | 09:31 PM
subgeniusdude's Avatar
Default another broken lca bolt
Just traded my 91 CRX for a clean 95 Integra LS.Has coilover sleeves but for some reason the rears were on wrong (perches were sitting on top of spring instead of bottom).So decided Id fix them and in the process snapped the head off the lower control arm bolt (14 mm).After I did that,I looked over at the other side and it too had been broken at some point and somebody had been driving it that way.Anyway,I have the Energy Suspension poly bushings ordered and Im gonna use a sawzall and melt the old bushing out like everybody says.I was wondering if I used a stainless steel bolt through the new bushings,would that help ? I know the bolt seizes to the bushing due to rust and then u gotta get new LCAs or use the sawzall and propane torch method.Why is this so common on DCs? I've had 15 Hondas and never a problem with LCA bolts until now.
Old Nov 14, 2009 | 05:58 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: another broken lca bolt
Use the stock bolts and apply a liberal amount of anti-seize inside of the bushing sleeve where it contact the bolt shank. The stock bolts are high strength.
Old Nov 14, 2009 | 07:47 PM
AllMotorDC4's Avatar
x2
I wouldn't trust no HomeDepot bolts or anything like that lol
Old Nov 14, 2009 | 08:27 PM
thumper64's Avatar
I have a friend with a Jeep that he offroads, and they use grade 8 hardware without issues. It's perfectly fine.
Old Nov 15, 2009 | 06:12 AM
1992blueGSR's Avatar
i bet someone put those bolts on with an impact, hardcore.
ive had a few tegs and never had this problem
id use oem bolts..
Old Nov 15, 2009 | 08:02 AM
Fibercation's Avatar
allways happens.....do what dogg says
JDMjackyboy
Jun 5, 2011 08:15 PM
sde780
Oct 28, 2009 02:36 AM
M@
May 17, 2005 04:35 PM
teg92
Feb 2, 2004 05:21 PM
VTECorona
Aug 5, 2002 06:17 PM
