FS: GSR longblock, JDM ITR Trans, GT2871R, more crap
Old Nov 13, 2009 | 07:55 PM
Toda Party's Avatar
Default FS: GSR longblock, JDM ITR Trans, GT2871R, more crap
Loc: 10954, NY
Contact: todaparty@gmail.com
I was putting together some parts for a swap in my EK but school sucks and priorities are priorities...blah.
I'll post detailed pics after I'm done w/ the semester...some of the stuff is from my old FS post so I had pics already...Check back once in a while, I'm sure i'm forgetting some stuff. Shipping extra, prefer pickup on motor & trans...will meet within 30-40 miles.
- JDM ITR trans (4.785 Final drive) with OEM LSD - Mint condition ~40K on it. Shifts fine, axle seals good, diff good. - $1100
- OBD 1 GSR Head & block - The motor has about 70K on it - Head was sent to CC Cylinder heads and has a street port with ITR valvesprings & retainers, gsr cams, skunk2 manifold. It's still there, so that will be shipped to the buyer.
The block is still stock, and I started to tear it down but stopped...The mains, crank and pistons are untouched, but I took off the oil pain, windage, pickup, and the various hoses and brackets on the outside...everything's labeled and in bags. I also have a set of 82mm RS Machines OEM replica cast pistons w/ new rings I can include in the deal.
- $600 for head
- $600 for block w/ RS machines pistons
- $500 for the block w/o pistons
- $1100 for head, block, pistons
- $1000 for head & block
Here's some pics...the pics of the head is BEFORE I sent it to CC Cylinder heads.
- Garrett GT2871R - a little bigger than a Disco Potato. 64 a/r w/ internal wastegate. Can include a B-series Edlebrock cast log manifold (i'm pretty sure it clears A/C). Comes w/ oil & coolant feed & return lines. Used for 600 miles - absolutely perfect working condition.
- $1000
- $1100 with manifold
- 3" Stainless downpipe with T3 5-bolt flange. Was going to use this on the GT2871R, but will need a different flange...or if you have a T3 5-bolt turbo, this will bolt on. - $125
- DSS Stage 1 bseries axles & OEM halfshaft - $175 for everything, or 60 for the half shaft, 120 for the outers.
- Bseries shift linkage - $60
- CRV AC bracket - used to keep the D-series AC Compressor when swapping in a B-series motor. BNIB - $120
- ACL Race main & rod bearings - BNIB - $100
- P75 converted to P28 by Xenocron with Demon / Neptune license - $385
- RC 550cc injectors - $250
- Vortech Adjustable FPR - have 1 purple, 1 blue - $40 each
- Si rear engine bracket for swapping B-series into EK's - $80
- Bosch Electric water pump from a Saturn ION redline - same as the ones Frozenboost.com sells for air-water intercooler setups - $75
- Mustang Cobra heat exchanger - $100
- Moroso Aluminum catch can with 2 ports, filter, & Bracket - $125
- ACT Streetlite 12.5 lb Bseries flywheel - used 5000 miles, no heat scars, no divots or anything like that - $160
- ONE HAsport B-series tranny mount - race hardness - I can't find the other 2 mounts for the life of me...$75
- 98 civic EX Vtec harness - used for VTEC bseries swaps in your non-vtec civic, comes with obd2 and obd1 clips - $180
RS Machines 82.0mm PR3 (B16) Pistons - $170 - Roughly low 11:1 with a 87.2mm crank and b16/itr head, ~11.5:1 with GSR head with 87.2mm crank. Comes with new rings, wrist pins, and a moly coating on the skirts. These are 180+shipping from RS Machines (ebay).
ITR Rods - $170 30k miles on them. Mint condition, were replaced with forged stuff for a boosted setup. Stronger than GSR rods, lighter than Eagle rods -- great for an all motor setup or mild boost.
Civic Si Brake Booster - $70
Civic Si 4 wheel disc proportioning valve FOR EK ONLY- $50
AEM 2.5” short ram tube- $40 - Bracket is cut off. No filter. Couple scratches.
DC/EG 19mm rear sway bar - $50 - I believe its a suspension techniques, but don't quote me. Comes w/ the bushings for the subframe, but no end links.
Phillips D2R HID bulbs & 03 Maxima ballasts - $100, will not sell just one unless you find someone to take the other.
Honda centercaps $30 – Rota ARE SOLD. – Hcaps are P/N 44732-S0X-A00
http://img.photobucket.com/albums/v3...e/P1000862.jpg
Compustar Alarm w/ Remote - $50 – Just the remote and the brain.
OBD2a (97)LS intake manifold w/ AIT & IACV(not in pic, will include) - $ 40
http://img.photobucket.com/albums/v3...e/P1000837.jpg
OBD2a (97)LS Water Neck (back of the block)- $15 shipped
http://img.photobucket.com/albums/v3...e/P1000849.jpg
OBD2a (97)LS Thermostat housing - $40 - thermostat, coolant sensor included
http://img.photobucket.com/albums/v3...e/P1000846.jpg
http://img.photobucket.com/albums/v3...e/P1000847.jpg
OBD2a (97)LS timing belt cover - $20
http://img.photobucket.com/albums/v3...e/P1000859.jpg
LS alternator belt - $ 10 - good condition, about 15k miles
http://smg.photobucket.com/albums/v3...t=P1000851.jpg
3” Exhaust 3 bolt flange- $15 – I cut it off so I could run an exhaust clamp. Its off a Lovefab 3” exhaust.
http://img.photobucket.com/albums/v3...e/P1000865.jpg
90 Degree mandrel bend intercooler pipe 2.5” - $25 - bead welds on the ends for sealing. Mild steel, 2.5”.
http://img.photobucket.com/albums/v3...e/P1000867.jpg
Stock EG Hatch DX Upper Control Arms Make Offer
http://img.photobucket.com/albums/v3...e/P1000616.jpg
Toda Party
Northeast (Sales)
Nov 14, 2009 10:10 AM
00 FBP ItR
Sep 18, 2003 12:22 PM
GZR4DR
Feb 14, 2002 07:15 PM
