Suspension & Brakes Theory, alignment, spring rates....
honda civic/integra rear lca bolts
Old Nov 13, 2009 | 01:14 PM
98Luder's Avatar
Default honda civic/integra rear lca bolts
hey i know that the honda rear lca bolts seizing is quite the ordeal
has anyone ever tried to use any other types of bolts that "might" not seize?
i had some spare time today so i went and researched some of these bolts. There seems to be actually 3 different types of bolts honda uses back there
90173-sr3-003 ribbed bolt pointy tip, used in all three spots on the rear lca of 99-00 si/Sir's
90173-st7-z01 solid bolt i believe, used on the lca to trailing arm i believe
90172-s04-003 solid bolt blunt tip, used on integra shock to lca
i thought they were seizing because of the ribbed bolts cause water gets trapped then allowing it to rust and seize, but i have seen the solid bolts seize/shear too. All of these bolts were coated/treated when i went to the dealership to look at them. Has anyone ever used any other types of bolts? or does everyone just use lots and lots of antiseize?
i was just curious and it was a slow afternoon
Old Nov 13, 2009 | 01:22 PM
TunerN00b's Avatar
Default Re: honda civic/integra rear lca bolts
Everyone just uses gobs of anti-seize on brand new bolts, but not until they're already upset over how difficult it is to take off the 15 year old seized in place stock bolts.
Old Nov 13, 2009 | 07:58 PM
batallic's Avatar
^^^ just use a **** load of anti seize, and because of weather snow salt will play a factor
and mainly age
Old Nov 13, 2009 | 08:24 PM
98Luder's Avatar
yea i thought maybe someone might have thought to try a bolt taht was made of a different material. I guess you just can't escape it, it is what it is.
thanks
beefcakehonda
Honda Fit
Sep 28, 2017 09:59 AM
Brewbot87
Suspension & Brakes
Jun 5, 2014 08:36 AM
oMek
May 6, 2004 01:06 PM
psdvette
Sep 21, 2003 03:53 PM
