new motor! sohc zc in ef sedan
Old Nov 13, 2009 | 12:22 PM
4g4dcruisin's Avatar
Default new motor! sohc zc in ef sedan
got the motor!! questions tho... it says "zc 4wd..." does that matter? also look at the dizzy plugs, mine are white and dont have the mounting bracket, possibly from re-pinning for MPFI?
other than that things look cool, a tad of rust in the oil cap threads and coming out of the thermo housing.
please tell me to take more pix in case anything is different.
Old Nov 13, 2009 | 12:31 PM
90RENOsedan's Avatar
Default Re: new motor! sohc zc in ef sedan
i dont' think the 4wd matters, because its bolted to a fwd. so you're good there. and the dizzy plugs are different because sometimes people take off the mounting brackets.
looks good.
finish the install!
Old Nov 13, 2009 | 12:35 PM
not only are the in a different location(mounted), they are a different color/shape than my plugs. im HOPING i can just splice the wires into the zc plugs and be done with it.
ALL of the plugs and clips are on the motor haha so im glad for that. also there is a plug on my thermo housing that i DONT have on my a6 thermo housing. you can see the plug on the TOP pic just under the dizzy plugs.
other than that, the only differnece is the shape of the intake manifold...its bigger towards the back/bottom. injectors are all there, freakin throttle cable is still there.
oh but its missing the downpipe of the exhaust manifold so i have to use my a6 exhaust mani until i find a 4/2/1.
Old Nov 13, 2009 | 12:44 PM
BiG ChOr!Zo's Avatar
got any better pics of the whole motor and how much did it come out to total...other then that it looks great...!!!
why don't you just use your a6 dizzy, and forget about splicing wires?
Old Nov 13, 2009 | 12:48 PM
only $429...i can go out and take pix. the heat shield is really dirty, but the oil pan and the gasket look freakin new! i'll post pics in the next few minutes i just have to go outside.
Old Nov 13, 2009 | 12:49 PM
because i may have a coil/ignitor problem. every now and then i'de get a puttering while pickin up speed between 3k-4k.
this was BEFORE i had the major problems.
Old Nov 13, 2009 | 12:56 PM
i only have one complaint about the company i picked this up from...
i called them in advance telling them i should be there around 12, i then asked if it would take time to load it up and if i need to give advance notice. (so they could package it), they told me "no its fine, just come down.".
so i get there and i see the motor, they write me up, take my money then out comes the forklift. i asked them "hey are you gonna pallet it?" and the lift operator says "no its almost lunch time, the pallet guys are on lunch and im about to go on lunch also." i asked "will this be ok in my truck?" he replies "i dont know".
so yea, lame customer service.
Old Nov 13, 2009 | 12:59 PM
swap the internals from the zc dizzy into your dizzy. thats a pretty simple job. alot easier that wiring.
Old Nov 13, 2009 | 01:00 PM
more...
Old Nov 13, 2009 | 01:07 PM
that motor looks pretty clean...i never bought from soken before and only from soshin but hey when you gotta eat you gotta eat
Old Nov 13, 2009 | 01:10 PM
i guess, but i called about 2 hours before i got there specifically asking if it will be a long process to load and if i needed to give advance notice. i told them i'de be there at noon, whatever as long as the **** turns over i can care less.
if anyone wants a full K24 swap, they got one, bunch of b16b and b18c5's too. amazing assortment of trannies and longblocks.
but yea its clean as hell, the hose pieces that are left look brand new...but i saw some rust coming out of the thermo housing so i dunno bout that. no signs of leaks anywhere tho...
Old Nov 13, 2009 | 01:13 PM
but yea whats up with the electrical connector on the thermo housing? and the thermo ground spot has seperate red and black wires going to it.
Old Nov 13, 2009 | 01:19 PM
see check it out...also, the flywheel bolts all say "AT", i better use my flywheel right? haha
oh yea im an idiot, the spot of rust i saw was from a dowel pin where the tranny mounts with the block.
Old Nov 13, 2009 | 01:22 PM
probably means that it came off of a auto vehicle and if it did then you know that the motor wasn't pushed hard at all...if your unsure just use your old flywheel and transfer all the external parts from the d16a6 to the zc...it also states on the website that they use nuxudol inside the motors to prevent rust...!!!
Old Nov 13, 2009 | 01:31 PM
i think its safe so say that since there is no rust in a location that housed only water...the internals of this engine is gonna be in pretty good shape.
and yea the valve cover says AT
Old Nov 13, 2009 | 01:32 PM
Deetz's Avatar
Crazy Honda Guy
Ok....a sohc ZC is just like a usdm A6 engine with a different can, thats pretty much it! From i can see, i guess its a OBDI
Also, since it came from a 4wd sedan with auto tranny, no problem. Use a 5 speed tranny and bolt up a flywheel and clutch assembly, it will work just great.
You will have to address the obd issue though
Old Nov 13, 2009 | 01:33 PM
Originally Posted by Deetz
Ok....a sohc ZC is just like a usdm A6 engine with a different can, thats pretty much it! Since you took no good tpics of the top of the engine or the dizzy plugs, i can't tell if you got an obd) or obdI model, but from i can see, i guess its a OBDI
You many have to address the obd issue though
what do you need to see to tell its OBD?
Old Nov 13, 2009 | 01:39 PM
here...
Old Nov 13, 2009 | 01:41 PM
what year is that motor...the stamp is located on the front of the head...!!!
Old Nov 13, 2009 | 01:42 PM
supposedly out of an 88-91 why? wtf am i gonna have to do to get this running...
Old Nov 13, 2009 | 01:46 PM
i cant see the stamp! the heat shield is covering the spot with the PM stamps.
if this is obd1, cant i just use my dizzy, fuel rail/injectors and just be done with it?
Old Nov 13, 2009 | 01:48 PM
4drEF's Avatar
Keyboard Humorist
That's not even a flywheel!
Obviously from an auto.
Old Nov 13, 2009 | 01:49 PM
what is the head code and year stamped...!!!
Old Nov 13, 2009 | 01:50 PM
but ill be ok with my MT flywheel and clutch...
