CHIRS RADO PRO-FWD 6.87 @ 197
Old Nov 13, 2009 | 12:07 PM
fabworxs's Avatar
Default CHIRS RADO PRO-FWD 6.87 @ 197
1st in the 6's
Old Nov 13, 2009 | 12:08 PM
ReDemoN's Avatar
DixielandImports Please
Default Re: CHIRS RADO PRO-FWD 6.87 @ 197
Wow no vid or anything.
Old Nov 13, 2009 | 12:13 PM
Allan DP's Avatar
nice in for video!!!!!!
A train's Avatar
i believe they are calling it bogus due to the .7 60 ft. It would be awesome it were true but they gave him no time on that pass and 1.1 under on the index! and they would kill the index if it were true!
Old Nov 13, 2009 | 12:26 PM
fabworxs's Avatar
they are calling it back
Old Nov 13, 2009 | 12:52 PM
Innes's Avatar
dang, that would of been some great news...
...should probably delete this thread to avoid misleading anyone
Old Nov 13, 2009 | 12:57 PM
fabworxs's Avatar
Delete...I agree.
Old Nov 13, 2009 | 01:13 PM
JO TECH's Avatar
Wow impresive!!!!! Congrats...
Old Nov 13, 2009 | 01:23 PM
1992Si's Avatar
Impressive, if it's true, but like it was said, that could kill the index.
Not something you want to do in Comp.
Let's not forget about:
46. Scott Kelley SS/EX 10.50 9.757 -0.743
Looks like Scott was a winner in round 1.
Old Nov 13, 2009 | 01:34 PM
4piston's Avatar
Who gives a **** about the index ha ha. That would have been so cool if the time was legit.
Rado probably put a big FWING that extends out after he launches to give him a 30 foot advantage to the timers
Old Nov 13, 2009 | 01:39 PM
ssc_thomas's Avatar
Everything I can find says the timing starts at the starting line and the E.T. stops at the finish and it is not a collective timing. So if the 60' is bogus that doesn't make the E.T. bogus. From what I can find those times are to that point and are NOT added together to calculate the final E.T. He left on green the system started normally and ended normally the malfunction at the 60' timer doesn't make the pass void. Anyone know any different? Everything I can find about the timing system says it should count.
Old Nov 13, 2009 | 01:47 PM
4piston's Avatar
Good point. I get random crazy 60 foots in my EVO at Muncie occasionally and my ETs are always the same as my normal 60s. Each timer measures time independently, but I could see where a delay in the beam when he left could affect all the timers down track.
Old Nov 13, 2009 | 01:56 PM
A train's Avatar
some times the beam activates off the rear wheels whick make the 60 awesome and the time crazy fast! same thing happened to me in pomona i ran my first 9 second pass lol and i think a 1.1 60 ft! sucks but i hear the car is kickn ***! also on a side note rado is also doing time attack at fontana this weekend double duty for the team! what a madhouse!
Old Nov 13, 2009 | 02:06 PM
tony1's Avatar
When I got a pass with an incorrect 60', the rest of the pass was bogus as well. Was running 9.80 at the time with 1.60ish 60's. Said I went 1.25 60' and 9.45.
If the 60' time is wrong because the timers started late, it's all wrong. If the 60' time was wrong because something tripped the 60' timers wrong then only that part would be wrong.
Old Nov 13, 2009 | 02:17 PM
4piston's Avatar
I still think he had a FWING trip the beams HA HA
Old Nov 13, 2009 | 02:36 PM
ssc_thomas's Avatar
I for sure see how the starting line beam not starting on time would throw the whole pass off. So I guess we need to know if the 330' 1/8th and 1,000' times are way out of whack. But to just call the pass junk off the 60' is bunk. I'm sure more info will surface and the right call was PROBABLY made, but Chris and the Offical NHRA Starter Rick Stewart are not exactly buddies
Either way The car is out and running hard! I've had my money on Chris to be the first in the 6's for a long time now. I still expect him to do it. Good luck to CHRIS AND HIS WHOLE TEAM!! at the time attack and good luck on putting a 6 up and leaving no doubt about!
Old Nov 13, 2009 | 04:11 PM
boostedcivicsir's Avatar
Mr. Badwrench
because of the discrepency, i am locking this thread.
my fingers are crossed he does it. rado is a cool dude.
GRS Motorsports
Nov 13, 2011 03:24 PM
tony1
Nov 19, 2010 07:35 PM
VtecCarHauler
Dec 8, 2009 06:04 AM
life sux die
Honda Motorcycles
29
Jan 30, 2009 04:38 AM
Lip
Aug 13, 2001 06:27 AM
