what size bulb do fog light use??
Old Nov 12, 2009 | 10:33 PM
aemafia15's Avatar
Icon2 what size bulb do fog light use??
i knw i ask alot of questions but cnt seem to find the size bulb for the fog lights on a 92 lude ??? does any one knw...
(ie. the low beam uses a 9006 and high beam uses 9005)
so wat bout the fog lights?
p.s not my car got it on google =]
Old Nov 13, 2009 | 01:35 PM
aemafia15's Avatar
Default Re: what size bulb do fog light use??
k i found out its an H3 bulb but that wasnt the problem, the lights still dnt work and the fuse is fine im so confused......
Old Nov 13, 2009 | 05:01 PM
minilogoguy18's Avatar
Did you just hook these up or did you have them working at some time?
Old Nov 13, 2009 | 07:00 PM
thiskid0001's Avatar
relay,switch ???wiring???
Old Nov 13, 2009 | 07:50 PM
aemafia15's Avatar
well previous owner had them already in, n it looks like in OEM spot on the left tweeter so it aint a mod, so im assuming once i got the car they just stopped working, and the bulbs look fine wen i took one out
any idea where the relay is at and how i check if its bad?
Old Nov 14, 2009 | 08:27 AM
It's under the dash on the driver side, you'll have to remove some paneling to get to it. It will be grounded to the cruise control computer and will have a brown plug going into it.
Old Nov 14, 2009 | 05:34 PM
aemafia15's Avatar
o ok.... is this relay only connected to the fog lights or is it used on sumthin else too
Old Nov 14, 2009 | 07:31 PM
No it's just for the fog lights, small black relay, pretty hard to miss. If you don't have one you can find the 4 wire brown plug taped to the wiring harness with blue tape. Check this picture to find it, you don't need the sub harness that's shown, just cut some of the loom/tape and pull the plug closer.
Old Nov 15, 2009 | 05:45 AM
lrayford's Avatar
yes i used that same thing to plug my relay in.. be careful though. as the factorty alarm uses the same type relay and is easyer to find then the foglight one.
when i did mine i was like sweet theres already a relay here but its not working/clicking took me hours to relize that deeper in the dash there was another one of these spots for a relay. so i just took the one from the factory alarm out (i got aftermarket anyways) and pluged it in to the foglight harness...
hope that helps, cuz i wish some one would of told me..lol
Old Nov 16, 2009 | 04:13 PM
94vtirozguy's Avatar
4th gen use h3 bulbs. 5th gen use h3c bulbs
Old Feb 22, 2010 | 10:52 PM
Kylesbb2's Avatar
New User
Thats my car!!!!!!!!!!!!!!!!! h3 bulbs i feel cool that you found my car on google!!!!
Old Feb 23, 2010 | 06:58 AM
Kronn 98SH's Avatar
Not sure why no one told OP to use the FAQ seeing as how this information has been there since 7/2009.
https://honda-tech.com/forums/honda-prelude-4/info-4g-bulb-sizes-2612027/
1yesfan
Dec 13, 2015 03:05 PM
88SeeOurEx
Apr 30, 2011 12:02 PM
theazndog
Jun 19, 2009 11:53 AM
CRexcellence
24
Nov 25, 2003 12:49 PM
