F20B Bearings?
These two threads seem to have some good info:
https://honda-tech.com/forums/honda-accord-1990-2002-2/part-work-f20b-2679884/
https://honda-tech.com/forums/hybrid-engine-swaps-18/f20b-h22a-2460204/
i didn't see anything about bearings in either of those threads, though they had some other good info
it's my understanding that F23/H23 main bearings and B16 rod bearings are the way to go. i haven't figured out specs on piston ring interchangability yet, but i assume you want to replace those too.
Ive got a built F20B. Rod bearings are B16, mains are H22a4/F23. You can buy rings from Hastings which all 3 rings match the F20B's exactly. I have an extra set of Hastings rings brand new in the box and a set of CP piston rings for an F20B which i cant use because i have an 88mm bore F20B now. Let me know if you need any more info. Rod bolts can be bought from an F23
99blackvti
Oct 27, 2005 12:46 PM
