CEL After 99 Civic SI Cluster Swap...
Old Nov 12, 2009 | 02:55 PM
kdawgy2k1's Avatar
Icon2 CEL After 99 Civic SI Cluster Swap...
Wassup HT??? Got a weird scenario here... I did a 99 Civic SI cluster swap in my 91 4DR and i now have a check engine light that only comes on when the car is slowing down in gear (basically an engine brake). I dont beleive its a knocking problem or anything that is very serious... It even happens when i keep the RIPem's (rpms) low (under 2500) and its a engine brake longer than like 4 seconds... Like i said, it didnt begin this until i did the cluster swap...
Any ideas HT???
Old Nov 12, 2009 | 05:57 PM
hamorhead's Avatar
Default Re: CEL After 99 Civic SI Cluster Swap...
pull the cel then get back to us with what it is
Old Nov 13, 2009 | 04:45 AM
kdawgy2k1's Avatar
Icon2 Re: CEL After 99 Civic SI Cluster Swap...
its code #17 VSS (vehicle speed sensor)
Im not 100% sure about how to correcty go about fixing this problem but, what i did was get a 93 civic auto speed sensor and made a contraption for it to fit into the speed sensor and i tucked it away behind the dash and ran a wire to the ecu since the ECU generates the signal since the 99 SI cluster is electronic... and BTW my speed sensor cable comming out of the tranny DOES NOT come out... its a 91 Civic 4DR LX
What to do???
Swap Sensors???
I think the speed showing on the dash gets a lil off after bout 70mph (+ or - like 5 mph i beleive)
Old Nov 13, 2009 | 05:23 AM
crx_si-r's Avatar
newbies. the VSS from a cable transmission does come out. otherwise how would you replace it when it goes bad? i believe there is 1 bolt holding it down.
Old Nov 15, 2009 | 01:36 PM
kdawgy2k1's Avatar
def not a newbie and im not about to sit here and aurgue with you about how long i been around hondas cuz you REALLY have no clue who i am and what i do concerning honda's!!!
Anyone have any ideas for this???
Old Nov 15, 2009 | 01:53 PM
ed4doorcivic's Avatar
can u put a pick of the cluster in ur car up?
Old Nov 15, 2009 | 03:45 PM
kdawgy2k1's Avatar
Sure can... ill put it up tomorrow...
Old Nov 15, 2009 | 04:22 PM
crx_si-r's Avatar
fix it yet
Old Nov 15, 2009 | 06:55 PM
KINGVEM^^ED6's Avatar
Pics¿¿
Old Nov 16, 2009 | 08:56 AM
badluckrex's Avatar
i know u said the cable wont come out of the tranny but it really should. but in any case u can put an ek speed sensor in ur ef tranny. but if ur cable is stuck chances are ur speed sensor will not be fun either. i have the oppostie problem i put a hydro tranny in my rex and had to swap the sensors.
sometimes u can free up the sensor from the tranny by puting it in different gears and rocking it a bit. mine was stuck not budging at all and then one day it just pulled out with very little effort. just my 2c.
EF OBD 0
Jul 31, 2011 12:28 AM
Diversion
Aug 23, 2009 10:41 AM
crxb16a90
11
Aug 6, 2009 08:44 AM
gkssn
Feb 22, 2009 07:08 PM
o_no_vtec
Oct 2, 2008 12:00 PM
