EGR control Solenoid H22A specific?
Old Nov 12, 2009 | 01:22 PM
ketchup's Avatar
Default EGR control Solenoid H22A specific?
Will a egr control solenoid from another motor work? or are they motor specific? same goes for the CVC.
I've checked part numbers and they are different but that may be due to the different mounting points on them. As the preludes have them mounted on the shock tower, other models have the egr control solenoid mounted on the firewall along with the CVC.
So will a egr control solenoid from a 1.5 1.8 or even 2.0 cut it for the 2.2 motor?
Old Nov 12, 2009 | 03:07 PM
92civlude's Avatar
Default Re: EGR control Solenoid H22A specific?
Some Preludes dont have a CVC valve. Ive been using frequency solenoids from 94-97 Accords,(plentiful in junkyards). The p/n is the same as Prelude. The CVC valve is not needed.
Old Nov 12, 2009 | 08:41 PM
ketchup's Avatar
Is there a difference in 'frequency' of the solenoids? or would all honda solenoids function the same. I mean they all are just grounded by the ecu to work and if they all are the same then one from a civic would work just the same as one from a prelude.
Old Nov 13, 2009 | 07:11 AM
92civlude's Avatar
Do you have a frequency valve from a Civic? Not many Civics have EGR. Older Honda EGR systems use a solenoid valve, not a frequency valve. 90-97 Accords and 92-01 Prelude, Civic VX, and EG Si all use frequency valves. A regular on/off solenoid valve will fail in place of a frequency valve. What valve do you have?
Old Nov 15, 2009 | 09:21 AM
ketchup's Avatar
I have one from a 91 crx HF and 94+ accord, both are listed as "EGR Control Solenoid Valve" on the diagrams below.
Old Nov 15, 2009 | 06:13 PM
92civlude's Avatar
I know that the Accord valve is in fact a frequency valve and I have used them on many H swaps. Not sure on the CRX valve. The Accord valve is the same as the Prelude and they mount on a nice bracket that makes it easy for custom, professional looking install.
hotair
Nov 24, 2013 01:34 PM
Dave9212
May 21, 2008 07:08 AM
Boostage
Jul 23, 2006 09:43 AM
