Suspension & Brakes Theory, alignment, spring rates....
do i need a camber kit with this tein setup
Old Nov 12, 2009 | 12:29 PM
HondaheadBigNick's Avatar
Default do i need a camber kit with this tein setup
Sport spec mono flex winding master
http://www.tein.com/products/mono_flex.html
it comes with Upper Mount w/ Camber Adjustment* -
Upper mounts are included for front and rear. TEIN utilizes various designs of upper mounts to increase steering response while still maintaining quiet operation. Most kits include an aluminum upper plate with NWB pillowball, while some applications use an aluminum upper plate with hardened rubber bushing (reduced noise).
*Vehicles with a strut type front design, a camber plate is incorporated into the mount, which gives 0-3 degrees of camber adjustment depending on the application. is that all I need is a camber kit still needed??ty
__________________
Old Nov 13, 2009 | 07:55 PM
batallic's Avatar
Default Re: do i need a camber kit with this tein setup
what car is it goin on, 95 eg super clean?
HondaheadBigNick
Suspension & Brakes
Nov 13, 2009 07:59 PM
kakahoya
Apr 21, 2008 05:13 PM
dx_rex
May 21, 2007 08:59 PM
jisu009
Apr 14, 2003 10:24 AM
YumVTEC
Nov 8, 2002 10:35 AM
