!! Exclusive Garage Sale !!
Old Nov 12, 2009 | 09:18 AM
CRXdaBEAST's Avatar
Icon3 !! Exclusive Garage Sale !!
List will be updated as more parts come in and more parts leave....
CRX
USDM center console---$10
rear speaker covers---$20 both
headliner for si with sunroof---$10
third brake light inner panel---$10
rear interior complete---$75
91 si door panel---$50
jdm rhd clutch cable---$75
front speaker covers---$30 both
88 cluster cover---$25
complete 88 moldings--- $100 doors, quarter, and fenders
complete sunroof from si mint with all hoses for water all seals and harness with sunroof switch---$250
cable trans from 91 si crx---$150
88 crx si cluster---$75
jdm crx door (no interior no glass no mirrors just mint doors)---$150
88 si driver side door panel---$75
88 si cluster cover---$50
crx sunroof molding---$30
crx left c pillar---$10
crx rack and pinion and rear cross member---$100
usdm driver side door---$50
EF Hatch stock wing---$20
EF MISC.
coin holder---$10
door handles---$20 both
steering column covers---$20
ef clock---$10
ef dead pedal---$10
jdm rhd throttle cable---$30
e brake handle---$10
jdm sir crx bezel with cover---$75
ef mugen lip used---$50
single cam ef axles driver and passenger---$100
ef door panles---$75
ef hood prop---$10
ef sun visors---$20
ef hood latch with cable---$20
ef interior door handles---$20
ef hood cable---$20
ef clutch cable---$30
ef throttle cable---$20
ef speedo cable---$20
ef cargo taillight cover---$20
ef sunroof motor---$50
ef front suspension fork---$20 both
ef e brake console---$25
B Series & D Series
gsr intake manifold---x2---$50
b16 intake manifold 2000 b16---$75
b16 intake manifold---x3---$50
D series Y8 Manifold---x2---$40
ls manifold---$20
b20 manifold---#20
zc sohc head---$75
ls head---x2---$50
stock rad fan---$10
BDL Bronze Fuel Rail---$120
Sk2 Carbon Composite Fuel Rail---$180
Sk2 Pro Series Cam Gears New---$180
Sk2 Tuner 1 Cams Brand New---$475
B16 Built Head (supertech springs, retainers, 3 angle valve job, full port and polish, complete with dizzy and intake mani no cams---$550
power 68mm throttle body b series---$100
gsr hydro tranny w/ carbon coated synchros mint no grinds---$650
obx type r b series lsd---$400 brand new
ls long block---b18b1 #2310068---$500
dc 4-2-1 headers---$75 (slightly dinged up)
apexi n1 muffler used---$75
single cam hydro tranny's one has a main bearing blown and the other has 1st gear blown all parts necessary to assemble 1 good running tranny---$150
stock b series spark plug wires---$50
9mm red spark plug wires for b series vtec---$75
3 inch flex pipe w/flanges---$50
auto meter tach with shift light---$100
ek manual door panels---$100 both
jdm rear fog lights---x5---$75
d.a. stock bumper lights---$20
Hondata s300 new already in the ecu tuned on once by yosolo---$600
hasport shift linkage for b series in a ef with energy suspension bushings---$120
place racing ef b series mounts---$200 new cable
hasport ef b series mounts with hydro mount---$300
hasport cable to hydro tranny conversion---$100
k series wrinkle red valve cover---$100
b series wrinkle red valve cover with -10 fittings 2 in the front---$175
b series spoon yellow valve cover---$100
brand new moroso oil pan b series---$175
moroso oil catch can---$50
endyne oil catch can kit---$150
purplr asr subframe brace---$180
purple password jdm tow hooks---$100
gold password jdm tow hooks---$75
green front datum tow hook---$50
purple beaks bar---$100
red benen tow hook rear---$75
golden eagle cam gears b series---$100 new
stage 3 competition clutch new---$100
msd 6a box---$50 used
broadway mirror---x3---$20
eg/ek aluminum aftermarket radiators new---$120
jdm road flares---x5---$20
d.a. stock headlights and corners---$100
eg stock door mirrors---$20
eg hatch with tail lights---$50
del sol rear filler plate---$50
d.c. teggy stock wing---$20
no lowballers come with real offers or keep it moving...
Old Nov 12, 2009 | 09:34 AM
Linked's Avatar
Default Re: !! Exclusive Garage Sale !!
is the stg 3 comp clutch the whole kit or just the disc or the pressure plate?
Old Nov 12, 2009 | 10:26 AM
CRXdaBEAST's Avatar
just the clutch, i do have the pressure plate used and a 12 pd flywheel as well if interested 300 for everything!
Old Nov 12, 2009 | 10:30 AM
JDM-JAMES's Avatar
for b or d-series
Old Nov 12, 2009 | 05:06 PM
memphisraines26's Avatar
i'm intrested in the clutch as well and if it's for a B series. i would also like a y8 mani if it's for auto, it that matters.
Old Nov 12, 2009 | 06:08 PM
CRXdaBEAST's Avatar
for b series and no it doesnt matter if its auto or stick but they are both stick
Old Nov 12, 2009 | 06:17 PM
JDM_JNKY's Avatar
pics of the oil pan?
Old Nov 12, 2009 | 06:25 PM
crdizzle6288's Avatar
what car is the asr frame for?
Old Nov 12, 2009 | 06:28 PM
got pics of the clutch and y8 mani? clutch disc or puck? sprung or unsprung? and will you ship? 46060
Old Nov 12, 2009 | 06:32 PM
ghosthatch's Avatar
ef dead pedal
y8 intake mani if 5 speed and has iacv, all sensors, fuel rail
si cable tranny, if theres no grinds, synchro grinds, high speed rpm grinds, bad bearings
whats the deal with the asr brace? used new? all hardware? what setup?
maybe even a front tow hook for eg, doesnt matter color, just cheapest
maybe even the pro gears
pm me :D
Old Nov 13, 2009 | 06:00 AM
CRXdaBEAST's Avatar
its a brand new moroso oil pan, still wrapped still has all paper work never seen a drop of oil.
eg,ef,dc
6 puck, sprung, stage 3 b series and ill ship if you pay for it
Originally Posted by ghosthatch
ef dead pedal
pm me :D
everything is mint pm me exactly what you want prices are above and we can setup payment and shipment if neccesary
Old Nov 13, 2009 | 07:34 AM
David12's Avatar
pics of both b series valve covers
Old Nov 13, 2009 | 12:43 PM
hottopic58's Avatar
Still got the B cams and valve cover
Old Nov 13, 2009 | 01:06 PM
2001B18C1GS-R's Avatar
pm me on flare if there brand new with mounting hardware and everything
Old Nov 17, 2009 | 07:33 PM
ghosthatch's Avatar
did i pm you? i think im waiting for a response. i still want more information on the parts i asked about
Old Nov 18, 2009 | 05:54 AM
dh-r's Avatar
can you ship the moroso pan in canada?
Old Nov 18, 2009 | 06:19 AM
Ferio4ya's Avatar
pics of gold tow hooks??
Old Nov 18, 2009 | 07:11 AM
213374U's Avatar
0x5359-0055
Community Builder
Man, for some killer parts. Wish my EF was up and running already so I could pick up some of these "non-necessities"
Old Apr 17, 2010 | 09:21 AM
karma28217's Avatar
d.a. stock bumper lights---$20 what year?
interested in both shipped to 28217
Old Apr 18, 2010 | 05:26 PM
zlambe's Avatar
PM Sent
Old Apr 20, 2010 | 05:48 PM
karma28217's Avatar
Originally Posted by zlambe
PM Sent
was this directed towards me? i havent gotten a PM
Old Apr 20, 2010 | 05:56 PM
Black Diamond's Avatar
Pics of that Apexi N1 muffler is it an Axel back or just the muffler??
LMK
Thanks, NICK
Old Apr 20, 2010 | 06:36 PM
switchjv's Avatar
send me a pic of the rear foglight. i will get one for sure.
Old May 10, 2010 | 12:24 PM
Thelugie42's Avatar
Will you sell me just the sunroof panel? if so how much?
Old May 10, 2010 | 06:33 PM
yaknowit11's Avatar
what car is the brace and bar for?
and pics of the filler plate?
thanks
