!! Exclusive Garage Sale !!
List will be updated as more parts come in and more parts leave....
CRX
USDM center console---$10
rear speaker covers---$20 both
headliner for si with sunroof---$10
third brake light inner panel---$10
rear interior complete---$75
91 si door panel---$50
jdm rhd clutch cable---$75
front speaker covers---$30 both
88 cluster cover---$25
complete 88 moldings--- $100 doors, quarter, and fenders
complete sunroof from si mint with all hoses for water all seals and harness with sunroof switch---$250
cable trans from 91 si crx---$150
88 crx si cluster---$75
jdm crx door (no interior no glass no mirrors just mint doors)---$150
88 si driver side door panel---$75
88 si cluster cover---$50
crx sunroof molding---$30
crx left c pillar---$10
crx rack and pinion and rear cross member---$100
usdm driver side door---$50
EF Hatch stock wing---$20
EF MISC.
coin holder---$10
door handles---$20 both
steering column covers---$20
ef clock---$10
ef dead pedal---$10
jdm rhd throttle cable---$30
e brake handle---$10
jdm sir crx bezel with cover---$75
ef mugen lip used---$50
single cam ef axles driver and passenger---$100
ef door panles---$75
ef hood prop---$10
ef sun visors---$20
ef hood latch with cable---$20
ef interior door handles---$20
ef hood cable---$20
ef clutch cable---$30
ef throttle cable---$20
ef speedo cable---$20
ef cargo taillight cover---$20
ef sunroof motor---$50
ef front suspension fork---$20 both
ef e brake console---$25
B Series & D Series
gsr intake manifold---x2---$50
b16 intake manifold 2000 b16---$75
b16 intake manifold---x3---$50
D series Y8 Manifold---x2---$40
ls manifold---$20
b20 manifold---#20
zc sohc head---$75
ls head---x2---$50
stock rad fan---$10
BDL Bronze Fuel Rail---$120
Sk2 Carbon Composite Fuel Rail---$180
Sk2 Pro Series Cam Gears New---$180
Sk2 Tuner 1 Cams Brand New---$475
B16 Built Head (supertech springs, retainers, 3 angle valve job, full port and polish, complete with dizzy and intake mani no cams---$550
power 68mm throttle body b series---$100
gsr hydro tranny w/ carbon coated synchros mint no grinds---$650
obx type r b series lsd---$400 brand new
ls long block---b18b1 #2310068---$500
dc 4-2-1 headers---$75 (slightly dinged up)
apexi n1 muffler used---$75
single cam hydro tranny's one has a main bearing blown and the other has 1st gear blown all parts necessary to assemble 1 good running tranny---$150
stock b series spark plug wires---$50
9mm red spark plug wires for b series vtec---$75
3 inch flex pipe w/flanges---$50
auto meter tach with shift light---$100
ek manual door panels---$100 both
jdm rear fog lights---x5---$75
d.a. stock bumper lights---$20
Hondata s300 new already in the ecu tuned on once by yosolo---$600
hasport shift linkage for b series in a ef with energy suspension bushings---$120
place racing ef b series mounts---$200 new cable
hasport ef b series mounts with hydro mount---$300
hasport cable to hydro tranny conversion---$100
k series wrinkle red valve cover---$100
b series wrinkle red valve cover with -10 fittings 2 in the front---$175
b series spoon yellow valve cover---$100
brand new moroso oil pan b series---$175
moroso oil catch can---$50
endyne oil catch can kit---$150
purplr asr subframe brace---$180
purple password jdm tow hooks---$100
gold password jdm tow hooks---$75
green front datum tow hook---$50
purple beaks bar---$100
red benen tow hook rear---$75
golden eagle cam gears b series---$100 new
stage 3 competition clutch new---$100
msd 6a box---$50 used
broadway mirror---x3---$20
eg/ek aluminum aftermarket radiators new---$120
jdm road flares---x5---$20
d.a. stock headlights and corners---$100
eg stock door mirrors---$20
eg hatch with tail lights---$50
del sol rear filler plate---$50
d.c. teggy stock wing---$20
no lowballers come with real offers or keep it moving...
CRX
EF MISC.
coin holder---$10
ef clock---$10
ef dead pedal---$10
ef hood prop---$10
ef sun visors---$20
ef hood cable---$20
B Series & D Series
ls manifold---$20
b20 manifold---#20
zc sohc head---$75
ls head---x2---$50
stock rad fan---$10
sonic47
Mar 22, 2010 09:09 AM
gunnerman
17
Jul 9, 2009 04:25 AM
